Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
Old 09-06-2002, 08:38 AM
Default Also need help with belts?
I want to put a 4 or 5 point system in my b&b and was just wondering what belts and how most guys are mounting them? any pics would be great
Greg
Old 09-06-2002, 08:22 PM
Cobra Make, Engine: B&B w/FRPP 347ci 450HP Crate
Send a message via AIM to OhBuoy
Come on, someone help Greg and I and others out here.
Tom
Old 09-06-2002, 08:29 PM
Double Venom's Avatar
Guys,
We sell and use M&R belts, always putting in four points, on occasion 5 points for required sanction tracks, but... I have no idea how you would mount them in a B&B. Sorry, wish I could help.
Richmond, Simpson, etc. are all good belts.
DV
Old 09-06-2002, 10:00 PM
Blubyu2:
Send me your address, and I will send you photo's and drawings.
Jerry2
Old 09-07-2002, 03:31 AM
Send me pics at tboyce@windycitycobras.com.
Tom
Old 09-09-2002, 08:38 AM
Jerry e-mail is yanksgp@acmenet.net any help would be great thanks..
Old 09-09-2002, 09:30 AM
Jerry,
I'd be interested in the info. as well. My e-mail jpilewis@aol.com
Thanks for the help.
Jon Lewis
Old 09-09-2002, 02:09 PM
I have a Midstates that I want to put 5 point harnesses in. If you don't mind, I'd be interested in any information as well. Thanks Richard rlucero@guidant.com
Old 09-09-2002, 07:37 PM
GREENSNAKE's Avatar
Default SEAT BELTS
Hey GUYs ! I can get a picture of mine if you need it or if your gonna be at RUN-N-GUN next week Take a look at mine or Heck if you bring the belts and tools ill help you out dont take long! Take care! Greensnake
Old 09-30-2002, 09:31 AM
Blake Olson's Avatar
Location: Right in the middle of the beautiful Texas Hill Country - Boerne, Texas,
Send a message via Yahoo to Blake Olson
Does anyone have suggestions, steps, and/or photos to put 5 point harness in a B&B after the body and interior is installed?
thanks
blake - wishing I would've done it before.
"They're lining up on both sides of the ocean..
and nobody's willing to compromise
in the search for the smoking gun..."
"Charlie Don't Surf!"
Old 09-30-2002, 10:03 AM
Mr.Fixit's Avatar
I would recommend putting in the submarine strap if you are installing the shoulder harnesses. That belt keeps the buckle assembly from getting pulled up into your ribs when you cinch down the shoulder straps.
Old 11-02-2002, 08:24 PM
TTT....
I'm also trying to figure this one out....On T-3's website they are adding a piece of square tubing to the outside frame rail. The only problem with this is that I already have my body on. Any help would be appreciated
Old 11-03-2002, 12:11 AM
Wow, T-3 did a lot of work on their site since I last visited 3 weeks ago. I think the tube addition is a T-3 special touch, I would love to know what others have done to install the belts.
Tom
Old 08-07-2005, 10:44 AM
jams's Avatar
Cobra Make, Engine: B & B
Anyone have any seatbelt harness pictures?
Did you need to use Bezels for the sholder straps?
Do you use a harness for everyday driving? Just curious!!!
Old 08-07-2005, 11:03 AM
jams's Avatar
Any preference between V or individual harness?
Old 08-07-2005, 07:36 PM
RobV's Avatar
Cobra Make, Engine: B&B, 351 W, TREMEC 600
I have installed a 5 point in my B&B and it went real well. I used Simpson's. I wanted the Y harness but they discontinued it. I bolted the submarine belt to the steel plate under the seat with the belt bracket sticking out enough to allow adjustment. The shoulder harnesses bolt through the first frame member behind the fiberglass behind the seats. The only problem is getting the angle right as it comes through the fiberglass and over the seats.
I chose not to use a V-harness because I wanted to finish the holes into the passenger compartment with bezels.
I can get pictures easily.
Rob
Old 08-07-2005, 07:47 PM
Jams, I do not have pictures. I know the newer frames have better mount locations to facilitate a better angle of the lap belt eye bolts (there is a welded pad inboard of the transmission tunnel tubes). Just go through the bulkhead and to an eyebolt mounted to the thick tube that makes the shelf behind the seats. BTW, you will probably need a right angle bit if you are doing it with the body on. I used bezels from finishline.
Old 08-08-2005, 06:01 AM
jams's Avatar
Thanks for your input guys.
Rob V. any pics would be appreciated.
Old 08-08-2005, 06:22 AM
jams's Avatar
What is the best length 50" 55" 60"???
Old 08-08-2005, 05:46 PM
RobV's Avatar
My belts are 55" Simpson's, part number: 29063. I also plan on bezels from Finish Line. I bought 4 bezels. See if these pictures help. I kind of described what I did in an earlier post.
