Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
Old 10-01-2002, 06:23 PM
Default Ign Switch And Ballast Resistor
HAVE TWO QUESTIONS---
1.TO ANYONE USING THE PAINLESS IGNITION SWITCH (80153),
DOES IT HAVE A START POSITION ALSO OR IS A SEPERATE
START SWITCH NEEDED.
2. I AM USING AN MSD COIL. MY IGNITION REQUIRES A BALLAST
RESISTOR. IS MOUNTING THE RESISTOR ON FRONT OF CYL
HEAD BESIDE THE COIL SUITABLE??
THANKS RON
Old 10-01-2002, 09:29 PM
Cobra Make, Engine: B+B 351w #112
My ballast resistor is mounted on the firewall. Can't help you one the ignition. I have a Haywire harness. Jim
