10-30-2002, 08:39 PM
Location: Right in the middle of the beautiful Texas Hill Country - Boerne, Texas,
B&B Upper Hose..
Can someone please uplaod some photos of the B&B upper hose set up that you did? Especially if you have a 90 thermostat housing.
thanks
blake
"They're lining up on both sides of the ocean..
and nobody's willing to compromise
in the search for the smoking gun..."
"Charlie Don't Surf!"
11-01-2002, 02:58 PM
I actually did some cutting and turning of that hose. It works ALOT better now. I will show you what I did when I get home. I'll snap a couple of digital photos and post them this weekend.
blake
11-02-2002, 09:53 AM
I used a #8996 hose from napa, but I'm using the 45 deg. therm. housing. I originaly bought one for a 88 mustang 5.0 and it would have worked with the 90 deg housing. Hope this helps.
11-02-2002, 09:57 AM
Here's a pic...maybe...
11-03-2002, 02:16 PM
havent got to the hoses yet but the motor mounts are killing me it is way out of linement any sug.
big kid
11-03-2002, 02:51 PM
IL
Cobra Make, Engine: B&B w/FRPP 347ci 450HP Crate
First, it is necessary to widen the slots on the mounts out a little to hold the proper size bolt. Then, I was told to leave the mounts loose on the engine and get them lined up with the mounting bolts. WOnce you have it leveled, tighten everything up. Worked well for me. I was swearing and everything the first time through.
11-03-2002, 05:26 PM
WI
Cobra Make, Engine: B+B 351w #112
I loosened my mounts on my motor. Bolted up one side. Used a large pry bar and pushed engine over to the other mount and bolted it in. Then tightend the mounts on the motor. Have someone help its alot easier. Jim
11-04-2002, 07:47 AM
I actually had to weld my motor mounts in(hired a rig welder with truck). We put the headers, pipes, motor-mounts,and everything on the car and fitted it. Put the motor where we wanted it, leveled it, then the welder tacked it in place. We then unbolted and took everything out of the car, took the motor out, and he welded it up.
11-04-2002, 08:51 AM
Cobra Make, Engine: SMC Motorcars 289
Blake,
Look at my pics on the left side of the screen where it says "View My Photo Gallery". I used a Coolflex before I went to braided stainless steel.
Co-founder of the Texas Cobra Club.
Dave "Ren Man"
11-04-2002, 09:29 AM
B&B top radiator hose
I have a B&B and could never come up with any hose that looked right. I then made an aluminum pipe and used hoses on each end. The pipe only had one bend in it. I used 90 degree hoses on the motor and radiator. Looks a lot nicer. Dennis Tapp 405-736-0705
11-05-2002, 09:44 AM
Here's what I used...It was a hose for a 1992 Mustang. But that hose, when left stock, goes around the alternator, and rubs on the alternator fan, and will cut a hole in the hose (learned the hard way). You can cut and modify it and it works great...re-route around the front.
blake
11-22-2002, 04:24 PM
blake do you have part #'s for the upper hose it is giveing me fits shelby
big kid
06-18-2004, 12:49 PM
IL
Any problem getting the air out of the hose using the 90 degree thermostat housing and that hose? I used the hose in the stock configuration and it does not touch the altenator or fan, and has a protective sleeve on it as well. The big problem that I have is I know I have a huge air bubble in my system, and cannot figure out how to burp it out with that hose!
Tom
