Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
Old 12-11-2002, 08:24 PM
Cobra Make, Engine: B&B w/FRPP 347ci 450HP Crate
Send a message via AIM to OhBuoy
Default Routing front wires
What path do the front wires for the headlights and markers take? I am thinking of running them up the passengers fender to the right turn and headlight and then across to the drivers side either running along the hinge support or further up in the nose. WOuld you guys do anything different? What type of clamps did you use to hold the wires in place?
Tom
Old 12-12-2002, 03:14 AM
Cobra Make, Engine: N/A
Exactly what I did. To get from the header area up to the headlight area, I ran the harness through a length of PVC pipe i bonded to the tire side of the fiberglass fenderwell. It really looks better than running the harness across that flat surface in plain view.
My harness is in the black split tubing, and it's secured by metal/riubber sleeved clamps every foot or so.
Never ascribe to malice that which can adequately be explained by inattentiveness.
Old 12-12-2002, 03:42 AM
What did you use to attach the rubber/metal sleeves? Any pictures?
Tom
