Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
Old 04-05-2003, 10:25 PM
fw209's Avatar
Cobra Make, Engine: It WAS a B & B 306, T-5, narrowed 9" - 4:11... Hope to replace it soon.
Question Brake lines
OK!! The suspension is in and temp rear tires on.. Brakes are in the AM.. BUT..... What size lines do I use? The book shows 1/4" the packing list says 3/16"? All of the fittings on the master are reduced to 3/16" as well as the front caliper hose's.. I know to use 3/16" from the fronts to the tee, but I think I need 1/4" from the master to the tee's (front and rear)? Am I correct in this thought? HELP! I shouldn't need a pro.-valve but if the line size isn't correct I am going to have troubles. I have 4 wheel disc & 11" GM brakes.
Thanks in advance
Fred
Getting ready for the next build. Got the 351W on the stand.
Old 04-06-2003, 09:14 AM
Slow Dawg's Avatar
Cobra Make, Engine: 2 Seat Roadster-by B&B, 460+ w/auto.
No no no no no no no!!!!! Fred, I don't know what happened, but we haven't used 1/4" lines since we discontinued using the 8.8 axles. ALL brake lines are 3/16". If you need pictures on bending and install, let me know. I may be training someone on installing brake and fuel lines possibly this week.
Nonconformist. Can't handle a real job.
Old 04-06-2003, 09:21 AM
fw209's Avatar
Thumbs up Thanks
Ron;
Thanks... I am glad I asked.. Now it is off to the parts store... Brakes by 6? I hope !!!!!!!!!
