Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 04-12-2004, 10:25 AM
Cobra Make, Engine: B&B w/FRPP 347ci 450HP Crate
Send a message via AIM to OhBuoy
Default Source for turnsignal lever
I seem to misplaced, among other small parts, my turn signal lever. Anyone happen to know of a good source for one? I checked the "HELP" section of AutoZone.
Tom
Old 04-12-2004, 03:00 PM
jams's Avatar
Cobra Make, Engine: B & B
I used a tilt steering wheel lever for mine. It only cost a few bucks. Regular directional levers are usually to long. They would need to be cut and then threaded.
I don't have a part number but the guys at the local parts store looked through the Help catalog and found one that fit. I think it was from some GM car. The key thing you need to know is the thread size. Try a few different screw sizes to see what fits. If worse comes to worse the tilt wheel lever from my 94 Chevy S-10 pickup fit like a charm. Order one from GM.
Good luck
Just enough knowledge to build a cobra and be dangerous...
You can observe a lot from just watching.
Old 04-12-2004, 04:45 PM
Cobra Make, Engine: B+B 351w #112
If you are using B+Bs steering column, its from a Mustang II. Jim
Old 04-13-2004, 06:42 PM
GREENSNAKE's Avatar
Default Turn Signal
You can use the one out of a Pinto or Mustang II Works Perfect
