Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
Old 04-01-2004, 04:55 PM
Cobra Make, Engine: B&B #281, 351w from The Engine Factory, and a Ford AOD from TCI
Exclamation Cooling Fan
B&B Guys,
How loud is your cooling fan? I'm having trouble hearing how good my engine sounds over the buzz of the cooling fan. This fan came with my kit. Anyone use something different maybe with a thermastat control, nice and quiet with good cooling results.
Thanks,
Kajun
Old 04-01-2004, 04:58 PM
ENTDOC's Avatar
Try the 16 inch high volume fan from Southern Rod.It is inexpensive 79 dollars or so and quiet(curved blades).I used a flaming river thermostat fan relay from them also. chuck
Old 04-01-2004, 05:20 PM
Tony Radford's Avatar
Cobra Make, Engine: Unique 427 SC, Southern Automotive 427W Stroker
Same goes for the Spal fans. I'm running a 16" puller, thin profile. I can't hear it unless the engine is turned off.
After a good hard ride.....oil pressure is over 50, temp is below 190, she idles and no new dents. LIFE IS GOOD!
Old 04-01-2004, 06:37 PM
pgermond's Avatar
Ditto on Tony's reply. I love my SPAL
Phil
http://www.uniquecobra.com/
Old 04-01-2004, 06:56 PM
Rick Parker's Avatar
Kajun:
Problem is "Your pipes aren't loud enough!"
Rick
Old 04-24-2004, 03:36 PM
Unhappy buzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz
Removed noisy fan today and guess what? Its a spal fan!
Old 04-24-2004, 04:41 PM
The straight blade Spals are much noisier that the curved blade models, but they move more air too.
Rick
Rick
Old 04-24-2004, 04:51 PM
pgermond's Avatar
I have no complaints with mine. When you need it, it sucks air threw like, well........... it moves a lot of air The only time I can hear it is when the egine is off, and it's just a soft hum.
Phil
