Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
Old 05-22-2004, 05:41 PM
Cobra Make, Engine: B&B w/FRPP 347ci 450HP Crate
Send a message via AIM to OhBuoy
Default GM Calipers for Mustang II conversion
What year/make are the GM calipers that are used with the Mustang II adaptor brackets. The banjo bolts that I got from Heidt's with my stainless lines were the wrong size, and ended up pulling 3 threads from the inside! I want to replace them to try to get the car up for inspection. I can always order new ones online, but if I could get them locally, I might be able to get them in tommorow.
Tom
Old 05-22-2004, 10:18 PM
Cobra Make, Engine: Classic Roadster with 427 center oiler
Tom
The ones that I am using are 1970-1977 Camaro calipers. The brake pads require a 1/8" spacer on the back of them because the Grenada rotors are thinner than the Camaro ones that the calipers originally fit.
Paul
life is short: eat dessert first !
Old 05-23-2004, 07:38 AM
Slow Dawg's Avatar
Cobra Make, Engine: 2 Seat Roadster-by B&B, 460+ w/auto.
Tom, question. Did you get the calipers from us? I think they are from an S-10. You'll have to call Barry to find out what years. The banjo bolts we use are HELP #13936(?) and 13937(?). I know the last #'s are 36 and 37. The 37's are about 3 threads longer than the 36. Think maybe you got the shorter ones?
If this doesn't apply to your brakes, then in the immortal words of one Roseanne Roseannadanna, "Nevermind!"
Nonconformist. Can't handle a real job.
