It's alive,It's alive
http://www.clubcobra.com/forums/b-b-cobras-speak-bryan-anderson/70561-its-alive-its-alive.html)
| double ugly |
06-29-2006 10:26 AM |
Shelby 4000 series also has the license plate light off set 3/8 inches left of center. Shelby angles the stripe to line up in the center of the light. It's the way the originals were, I guess.
John
If the "off-centeredness" would be identified as a design element of the kit or the original by the kit manufacturer, it would have been very helpful in the paint design process. I sup0pose I should have checked it prior to paint, but assumed that it would have been close. But ... you know what they say about assume.
Rob
| lnfletcher |
06-29-2006 11:39 AM |
Man Rob, I'm impressed! I could not ever tell by the finished pictures. I think I may just go stripeless! Seems like assuming with these cars is double trouble!
I like the look of stripes. I have seen some solid colors that really look sharp, but, I think the stripes give the car that "I go fast" look.
Rob
| pmfranke |
07-04-2006 11:50 AM |
nice to know there are anal people like me who notice things like off center scoops and tail lights. Grreat job . did you center up the tail light or move the stripe? I like the stripes too and wonder if you adjusted the width(fatter at the cockpit ) or not? Peter.
I reworked the license plate light also. I moved the stripes as far as I could, but they would conflict with something else like the radiator openings, the roll bars (I used two), etc. I went with the specs the ERA folks put out that give the dimension of the stripes; wider at the top and smaller at the bottom. I obviously went with the small 1/4" stripe outside the main stripes.
Rob
| pmfranke |
07-07-2006 03:36 PM |
thanks ,keep up the good ,great work. peter
| All times are GMT -7. The time now is 05:19 AM. |
