Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Old 10-13-2006, 07:38 PM
Cobra Make, Engine: B&B 302 GT40, T5 5sp, 9"rear end
Default Clutch cable
Ok do you just stick it in the hole or is there a clip that goes on behind to hold it in? Looks like there is a hole for a small bolt is that it? When I got the cable it was just the cable.
Thanks
Old 10-16-2006, 06:50 AM
lnfletcher's Avatar
Cobra Make, Engine: B&B 427 Stroked Windsor TKO 600 w/3.50 posi 9"
If your talking about the bell housing side. There is a clip that holds the cable jacket to the housing. On the upper side, the tension holds it to the cable hump. The only bolt hole that I know of is for the clutch arm cover.
