Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
Old 03-09-2007, 08:15 AM
Cobra Make, Engine: B&B, 302 Ford crate motor
Default pmfranke
On Dusty Rhodes wheels did you notice he has an 8.8 abd you have a 9"?
There may be some difference in lenght so the offset of the wheels may need to be adjusred.
1993 Mustang Cobra
Old 03-09-2007, 10:21 AM
Cobra Make, Engine: B&B 351w
the rearend is a narrowed chev rearend, 54 1/2" from axle flange to axle flange
Dusty Rhodes
Old 03-10-2007, 07:59 AM
Default Dusty Rhodes
Thanx for the correction. I have a slight bind in the steering too. I didn't think it was bad enought to worry about but now that you mention it, what did you do to correct it? Your front sway bar looks perfect. It is from a '68 Camaro?
1993 Mustang Cobra
Old 03-10-2007, 10:24 AM
the swaybar is from an 1986 camaro. On the steering I cut the bracket off ( the one between the firewall and steering rack that holds the bearing), and turned it around so that it would be closer to the motor. problem solved.
Dusty Rhodes
Old 03-10-2007, 07:37 PM
pmfranke's Avatar
Cobra Make, Engine: B&B 351/402 Fi roller everything
mine is a 9" ford that's 54 1/2" also.my spring are too short (oil pan 3 1/2" clearance) so i'm looking for 10" free length.dusty's springs look like 2 1/2" id all the way up into the mustang II cup.Unlike mine that have two different sized ends 2 1/2" and 3 1/2"at the top. With the streight springs , there are alot more choices of length and rate. the Camaro sway bar does look perfect . how to mount to the tubular A arms is the next question.
the older i get the faster i was.
