Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 06-05-2007, 02:01 PM
Cobra Make, Engine: BB, Ford 351/385hp
Default headlight trim rings & oil cooler question.
1. I just bought one of your B&B Cobra's and need to change one of the burnt out headlights. Trim rings have no screw on the bottom....do they just snap off or should I unbolt the entire bucket.
2. I want to install your oil cooler.....please tell me what I need to order from you and the cost. I have a 351W.
Thanks.
Steve Hendrickson (you have my name on file, if you need any more info)
Old 06-05-2007, 07:10 PM
MacGyver's Avatar
Cobra Make, Engine: B&B 5.0 roller W/carb & T-5 WC
I went through the same thing when I first bought mine. The rings release from the bottom. You can use your fingers depending on how tight they are or a plastic pry tool gently pulling it out at the bottom then lifting when the bottom releases. It should be straight forward from there. Matt
Old 06-07-2007, 08:19 PM
BeasleyRB's Avatar
Cobra Make, Engine: B & B , 351W 400+
Steve,
Brian doesn't really read this forum. Call him if you need to talk to him. They are happy to answer questions on the phone.
