Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
Old 08-15-2007, 05:50 PM
Default speedo cable
Is anyone using the TKO 600 with the Faria speedometer? Can you tell me what I should be looking for to order the speedometer cable? Also, what do I need to get to hook up the neutral safety switch?
Corey C
Old 08-15-2007, 09:26 PM
Senior ClubCobra Member
You'll need to get your speedometer calibrated, so don't buy a cable yet. Just go to a shop that calibrates speedometers and let them hook it up. They may have to add a widget that adjusts the revs out of the transmission (I did) anyway.
Old 08-16-2007, 07:57 AM
lnfletcher's Avatar
You need to calculate what gear needs to be in your transmission. Easy to install but is different for what rear gears your running.
Old 08-27-2007, 03:46 PM
BeasleyRB's Avatar
Cobra Make, Engine: B & B , 351W 400+
The cable isn't a problem. You need the correct gear to go on the end of it that is inserted in the transmission. Call Standard Transmission in Dallas/Ft. Worth and they can fix you up. Need wheel height and rear gears. The Faria Speedo indicates 60 mph at 1000 rpm cable speed. I got my gear from Standard and was surprised how accurate the speedometer is. (I just didn't expect it to be right) I got my cable from Oreilly Auto.
