Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
Old 12-06-2007, 01:23 PM
Cobra Make, Engine: various,289 HiPo
Default Front end body attachment
What is the clearance between the body and the vertical posts from the frame? Could someone get a picture of the attachmet of the "chin" support to the frame and body. Mine was not attached when I received my frame. Have any of you installed an air splitter coming off the horizontal frame member? Pictures?
Thanks for your help. All is appreciated.
Old 12-06-2007, 05:46 PM
Cobra Make, Engine: B&B,351/385hp,Silver/Black stripes
My body is sitting right on the uprights, there is an extra small fiberglass pad between the body and the uprights. Don't have a splitter but I would advise you to either use the B&B aluminum nose peices or at least bend up some aluminum between the bottom of the nose opening and the bottom of the radiator. You can bend up the sides and attach to the inner frame rails.This dropped my coolant temp by 10-15 degrees.
