Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
Old 02-25-2008, 02:17 PM
MacGyver's Avatar
Cobra Make, Engine: B&B 5.0 roller W/carb & T-5 WC
Default Headlight Gaskets
Does anyone use a rubber gasket between the headlight assembly and the body on the B&B? When replacing a headlight I noticed the ring makes damaging contact with the body. At the time since this was my first experience I thought that was the way they were. After being exposed to several other Cobra's I noticed most of them have gaskets. Here is my main Questions. Does B&B make a headlight gasket? Will the Finishline one fit? This seems like an oversimplified question but looking at several cars some of the rings have different shapes and I'm concerned with proper outside diameter...Thanks!!!! Matt
"Oversteer is when the passengers are scared. Understeer is when the driver is scared."
Old 02-25-2008, 04:36 PM
JCoop's Avatar
Here's what you need:
SEAL HEADLAMP HEADLIGHT With LUGS
Ray
New York
SPF#1052 11mpg
CAV GT40 MONO29 9mpg
'01 MB CL600 V12 18mpg
'08 Volvo S80 18mpg
Old 02-25-2008, 07:23 PM
SuperHart's Avatar
Send a message via AIM to SuperHart
These gaskets are available almost anywhere that headlight parts are sold. The gasket you need is for a standard 7" round headlight bucket. Most any English car that used a 7" round headlight used the same gaskets, Triumph, MG, etc.
Old 02-28-2008, 04:24 PM
BeasleyRB's Avatar
Cobra Make, Engine: B & B , 351W 400+
Brian at B&B has the gaskets. Lights look better without them.
