Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
Old 06-09-2008, 05:06 AM
Cobra Make, Engine: B&B...351/393w
Default Electric Water Pumps ???
Anyone use an electric water pump, pros and cons?
Old 06-09-2008, 09:28 AM
Default Drag racing only
wfieldin I have only used electric water pumps for drag racing only. You are only going to save about 3-5 HP by driving the pump off the motor. Most electric pumps are good for about 1K hours before rebuilding. You can get an Edelbrock Aluminium water pump that weights less, setup a set of pulleys from March and have a real nice setup. Kirkham sells a better set of machined pulleys for a cobra. You have to watch when you go to underdriven pulleys and have a radiator that can't handle a worked out motor. Big or Small block. You are still going to need a belt for the Alt for charging.Stay with a 1-1 drive for the crank to waterpump or get an overdrive system which works better on the hot 100+ temp days. Rick Lake
Old 06-09-2008, 09:41 AM
Cobrabill's Avatar
Cobra Make, Engine: Superformance 427 Side-Oiler
Electric water pumps are quite useless for the STREET.
The rest of the world can have their opinion about the United States just as soon as WE give it to them.
Old 06-09-2008, 06:26 PM
Cobra Make, Engine: BDR 559. 410 Stroker 72 block AFR205 Heads, Solid roller lifters, Comp Cams XR286, Eagle 4" stroke internally balanced with chevy journals, Oliver rods, Probe Forged pistons, Mighty Demon, Super Victor, MSD Digital 6.....
Been using mine for 1 1/2 years with NO problems here in HOT and SUNNY Florida... Love the unique look, quiet operation and the fact that I can change out the motor if needed within 5 mins (haven't had to). I can also circulate coolant w/o the motor running for quicker cool downs while at the track too....
Pictures in the gallery.
BDR 559
Indigo Blue, White Stripes
SBF 410
TKO 600 .82 OD (Road Race)
HP= Enough!!
