Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 05-26-2008, 04:24 PM
Cobra Make, Engine: BB, Ford 351/385hp
Default Power Brakes
Has anyone installed power brakes on thier B&B. If so how and what make. Thanks for any input.
Old 05-26-2008, 07:51 PM
BeasleyRB's Avatar
Cobra Make, Engine: B & B , 351W 400+
I'm not answering you question, but my car stops well with the 11 inch non power brakes. Maybe you need power brakes for some reason but if you are just buildling your car I would check into this more before you go to the expense.
Old 05-27-2008, 04:47 AM
1985 CCX's Avatar
This winter I converted from 1960's Jaguar power assisted brakes to non-power Wilwood calipers and masters. I think the Wilwood set up is much better. These cars are 2000 lbs give or take so power is not vital. I have driven SPF with power, they are great just more sensitive.
Old 06-04-2008, 09:15 PM
2006GT's Avatar
Cobra Make, Engine: SC MotorCars, 302
Where's a good place to get the Wilwoods? Any suggestion? Thanks!
1966 Cobra Replica (SC Motorcars) Restoration in progress...
2006 Mustang GT
President- Bold Moves Mustang Club of Tulsa. www.boldmovestulsa.com
Old 06-08-2008, 07:32 AM
Cobra Make, Engine: B&B
Default power brakes
Cobras are very light and I really don't see a need for power brakes. I used the Wilwood 11" rear brake asssembly that bolts right to the ford axle and has a built in parking brake. Speedway part #835-1406696. For the front went with the 11" granada rotors, and adapter bracket from heidts and the same wilwood calipers used on the rear. Stops great. Only modification was to put a brake modulator in line to proportion more of the power to the front wells. Pics and details in my gallery.
Old 06-08-2008, 02:01 PM
2006GT's Avatar
Found these and the price seems to be right. Item # WIL 1408652 http://www.hotrodsusa.com/store/brakesmustang2.html
Even comes with proportional valve, SS lines and free shipping...
2006 Mustang GT
Old 06-08-2008, 02:09 PM
2006GT's Avatar
I found a Wilwoods kit (part#WIL 1408652). They throw in SS lines, a proportional and free shipping. $685... not bad. http://www.hotrodsusa.com/store/brakesmustang2.html
2006 Mustang GT
Old 08-24-2008, 04:27 PM
pmfranke's Avatar
Cobra Make, Engine: B&B 351/402 Fi roller everything
Racer 1 i know what u mean because th peddle is so hard to push.the brakes stop but with a lot of effort. I bought a mini cooper with willwood brakes an stopping in that car pulls the fillings out of your teeth. when i find an extra 1000 bucks ill throw a set of willwoods on my car.Duke You are happy with your setup?
the older i get the faster i was.
Old 09-17-2008, 12:40 PM
RobV's Avatar
Cobra Make, Engine: B&B, 351 W, TREMEC 600
I changed to the Wilwoods from the stock Ford set up. I didn't like the feel and I liked the idea of the built in parking brake. The Wilwood set up suits me fine and I have had no problems. I put in a proportioning valve, thinking I would need it. I probably could have gone without it.
Rob
Old 09-25-2008, 09:30 AM
Cobra Make, Engine: B&B...351/393w
If you were going to pick one to upgrade, would you do the front or back first? I have stock GM style disks currently.
Old 09-25-2008, 10:04 AM
RobV's Avatar
Since 60-70% of the braking is accomplished with the fronts, I would certainly go there first. Consider the proportioning valve if you're going to mix systems. You don't want to create a situation where you can't get the right balance. I would also recommend that you call Wilwood and tell them what you want to do and get their expert adivce on the mix of systems. They are good folks and they are the experts not me.
Rob
