Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 01-13-2009, 01:35 PM
Default Puller Fan and seat belts
I need to purchase a cooling fan to go with the B&B supplied radiator. I have selected the Summit aluminum shroud and fan combo (16 inch diameter, 4.5" thick, 2215 cfm, part number 381008) for $170. Has anyone used this set up with success or is there a better option?
One of the last things I need to purchase is the seat belts. Is there a good 4 point harness that someone can suggest? No track, street only.
Thanks,
Corey C
Old 01-13-2009, 07:23 PM
Senior ClubCobra Member
Cory,
I don't have the original radiator anymore, but looking at my current setup, it doesn't look like a 4.5" puller will fit. Won't the steering rack get in the way?
FYI, B&B was formerly LA Exotics
Old 01-13-2009, 08:23 PM
Cobra Make, Engine: B&B, 428 FE, toploader
Cory, I had B&B make a shroud for the aluminum radiator that I got from them and then used the 16" fan that originally came with the kit. It worked perfectly. Chas
