Old 10-11-2009, 07:16 PM
wrogers55's Avatar
Cobra Make, Engine: Backdraft #318, 418 CI, 532 RWHP, Mass Flow Injected, TKO600-Road Race, BMW M3 Suspension, Race Springs (Wouldn't do it again, rough on the street).
Default Spring help
I'm told my new to me Backdraft 318 has race springs on the rear....and maybe the front as well. I rides like a go cart with very little suspension movement. Anyone know the spring wire diameter of the current "standard" street spring, front and rear. Maybe knowing the race spring numbers as well would help me go in the right direction. Any help appreciated. Thanks, Wayne in Gilroy CA
Old 10-11-2009, 07:57 PM
Cobras don't have much suspension movement and should be somewhat stiff in order to handle well. You can't tell the spring rate by the diameter of the spring. Get under the car (jacked up) and spin the spring around to check if there is a brand name on it, then look for colored paint marks which will tell you the spring rate per the mfg's code. There really isn't a race or standard spring, just spring rates. Just remember, it's not gonna ride like a family car, it's basically a race car for the street.
" It ain't no big deal"
Old 10-11-2009, 09:24 PM
Cashburn's Avatar
Backdraft Racing Dealer
BDR race springs are generally blue vs. the standard red springs.
IT'S NOT REAL. IT'S UNREAL.
VINTAGE MOTORSPORTS
Old 10-14-2009, 08:08 PM
Rwillia4's Avatar
Unless you have a hugh understeer or hugh oversteer, you have matching springs front and back.
...Errr- I replaced my black standard springs with red race springs
Old 10-14-2009, 08:34 PM
Cashburn's Avatar
Where in the world did you get black springs?
VINTAGE MOTORSPORTS
Old 10-14-2009, 08:39 PM
Rwillia4's Avatar
Well in the front they were located around the strut... lol
$hit I don't know where half of the stuff on the car came from when it was rolled into my garage!!
...they probably came out of some SA Datsun
Old 10-16-2009, 02:13 PM
Send a message via AIM to tony martin
Talking springs
FRT SPRINGS
ROAD 11-12MM WIRE
RACE Q3-14MM WIRE
REAR SPRINGS
ROAD 17MM
RACE 19MM
ANYTHING IS POSSIBLE!!!! WOTS A DATSUN???
mr lucky
Old 10-16-2009, 03:25 PM
jp65cobra's Avatar
Cobra Make, Engine: BDR #259 351W
So if you switch to race springs should you also be changing your shocks to match?
Old 10-16-2009, 05:15 PM
Rwillia4's Avatar
Well some shocks will give you a better feel with some springs and generically work better for performance. But the spring and shocks do not need to be changed together. And there is plenty of different opinions of which springs work best with which springs, this is a personal preference that can only be answered by your driving style.
I like a firm/stiff car that doesn't “flop” around a turn and has a much more aggressive breaking point (when the oversteer or understeer begins) and more difficult to control. Others like to have a softer car where the breaking point is much more gradual and easier to control once you begin to pass that point.
Race springs are going to make the car tighter, roll less.
The combination of race springs and stiff shocks will make the car more precise and have a quicker response to any driver input. The negative side is the cars ride is stiffer.
There is another component that can vary the handling dramatically: sway bars or roll bars. These need to be changed out in pairs (front and back) the bigger the bar the stiffer the suspension. What they do is mechanically connect the left side with the right side. So that if the left wheel goes up the right wheel. The distance the right wheel will come up is dependent on the size (diameter) of the bar. The bigger the bar the more the left and right will come up the same distance and the tighter the car. The flatter the road the bigger roll bar you can use. You will increase your capabilities, but there are some downsides in ultimate controllability.
Example: If your car is stiffer the result would be similar to running to a cliff edge as fast as you could trying to turn at the last second, you accidently wait too long and falling off the edge you would try to regain control all the way down, which is difficult as you fall down. A softer sprung car would be similar to running across a mound and go over the top while trying to turn you miss the top but you can still turn and return toward the top. You get the edge fast with a stiffer car but if you push it past the edge it is more difficult to handle.
What is the best combination? Like I said before it depends on your driving style. A web search on “oversteer vs understeer” will give you some ideas on how to adjust your suspension to match your needs and capabilities.
Rob
Old 10-16-2009, 09:41 PM
eschaider's Avatar
Wayne,
This might help determining how zesty your springs are. Click here => http://www.jblmotor.com/spring.htm.
If you want to get together and tell lies PM me we can't live but a couple miles apart.
Ed
Old 10-17-2009, 05:34 AM
Default What are you doing with the car
wrogers55 Wayne did you ask or tell the guys at Backdraft what you where going to do with the car? I am sure like ERA they setup the car for the middle of driving between total street and total roadracing. The easiest thing I can tell you is to get the street setup of springs and shocks, and then after you have some time with the car, you can swap them over to a race setup for better handling. Other safety equipment will be needed when you get the bug for going fast. Shocks come in different lengths and have single and multiable settings for rebound and compression. Springs come in all lengths and spring rates. Most are messured in how much weight is needed to collapes the spring 1" This gives spring rate numbers, the lower the softer the ride. You will also need to know length for height of the car ride. Have BDR do the alignment and weight and balance the car in the 4 corners. Tell them your real weight so they can setup the car correctly with you driving it alone. This will be a good starting point for you and your new friend. Rick L.
Old 10-18-2009, 05:03 PM
It seems Rob tries to sound intelligent here regarding springs and shocks...
but he needs to google a few more "handling" sites...BTW, the word is "huge"...
Unless you are really "racing" your car much, or are extremely overweight, the stock springs and shocks with some ride height adjustments will serve you just fine...
I am sure T. Martin has selected the correct springs on these car for 99% of the buyers...
Old 10-18-2009, 05:52 PM
A quicker and easier adjustment to "soften" your car up would be tire pressures.
A Backdraft replica has very little area for tire clearance. A softer spring will cause a "tire rub" issue. Ride heights are critical. The nature of this car.
Old 10-18-2009, 06:23 PM
Rwillia4's Avatar
cbreez I always forget how smart you are... good job with some constructive input.
Old 10-18-2009, 06:29 PM
My input is always constructive. Thanks!
Old 10-19-2009, 09:45 AM
Doug I's Avatar
Cobra Make, Engine: Waiting to Order a BDR, engine to be a SA C408. TKO to hook it up.
I'd forgotten how nice his car is too.
Pull a gear .... drop the hammer .... and enjoy the Drive !!
Old 10-21-2009, 08:40 AM
Blittleton's Avatar
CC Member / Sponsor
Wayne,
We never changed the front springs. They are the originals that came with the car. Mike change the rear due to bottoming out.
Bill
www.gcperf.com
