February 2026
Like Tree1Likes
  • 1 Post By Bernica
Old 03-13-2010, 09:15 AM
Sledge's Avatar
Cobra Make, Engine: BDR #168 427W 69+K miles and counting
Default P/N for column-mounted turn signal switch assy
I need to replace my turn signal switch assembly on chassis 168. I think it is a VW Beetle 66-67 switch but am not sure. Anybodyt know the correct part number?
Yes I've searched both here and at Backdraft Boys. No I haven't removed it yet because I can make it work until I get a new one. I called Reg at BDR but no one's home today.
Bill
"If your work speaks for itself, don't interrupt"
Old 03-14-2010, 08:44 PM
I believe this is what you are looking for. Saw someone else post this as a replacement once.http://cgi.ebay.com/ebaymotors/66-67...ht_1334wt_1258
Old 03-14-2010, 08:56 PM
Cashburn's Avatar
Backdraft Racing Dealer
ACDELCO Part # E6205A
STANDARD MOTOR PRODUCTS Part # TW33
AIRTEX Part # 1S7267
No guarantees because all these companies have a tendency to put other things in the boxes. But it's a start. You have to grind out the inside some to clear the factory column size.
IT'S NOT REAL. IT'S UNREAL.
VINTAGE MOTORSPORTS
Old 03-14-2010, 10:50 PM
twobjshelbys's Avatar
What about the Shell Valley part?
I'm looking for one with return/self cancel...
Old 03-18-2010, 07:58 AM
Sledge's Avatar
Thank you Cashburn, Two and True:
I went to my local VW parts store, secured an OEM replacement for a 66-67 Beetle, ground down the i.d. (as others have reported necessary), and got it installed last night. I don't know if they are all like this, but the OEM switch assembly is much more substantial than the cheesy lightweight switch assembly that came with the car. Costs a lot more, too. Worth it imho.
Bill
Old 03-18-2010, 10:20 AM
Bernica's Avatar
Senior CC Premier Member
I know Shelby was using the VW unit on their CSX4000 series cars. It's a non-cancelling, right-hand side assembly.
ront49 likes this.
Old 03-18-2010, 07:35 PM
Indeed, that's what is on mine.
Old 03-18-2010, 10:33 PM
rokndad's Avatar
Cobra Make, Engine: CSX 4758, CSX 381 Keith Craft 482 w/ Weber 48 IDA's
Been on the sidelines for a long time, with major health issues. Mike, you are right and not right. The unit is self cancelling if you drill and tap a small screw into the shaft where the self cancelling pawls are. I didn't have a hole in my column so I drilled and tapped and slipped a very small headed stainless phillips screw in there and it now cancells.
[IMG][/IMG]
Old 03-18-2010, 08:49 AM
Cashburn's Avatar
When it comes to VW parts you can choose the quality level by where the part is made. Usually on the turn signals you can choose:
1. China
2. Mexico
3. Brazil
4. Germany
etc.
You will pay more for the German, but you will buy 1.
VINTAGE MOTORSPORTS
Old 03-18-2010, 09:44 PM
Cashburn's Avatar
The VW unit is canceling if you setup the hub properly...
VINTAGE MOTORSPORTS
