Old 11-20-2010, 04:26 PM
Cobra Make, Engine: BDR 347 Stroker
Default Brake Pedal spacing from gas pedal
Has anyone modified the brake and clutch pedal to move both a bit more away from the gas pedal? Looking at the mounting. it looks as though offset tabs from center would help.
Old 11-20-2010, 07:31 PM
Mac VABCH's Avatar
Cobra Make, Engine: BDR #250
You can heat and bend the pedal arms fairly easily, I did this to mine only get you about 1/2 in though...Mac
Old 11-21-2010, 05:40 AM
I took this photo which shows how the prdals are mounted. I was thinking about fabricating a set in which they were off center. This would move pedals about a 3/4".
Old 11-21-2010, 06:14 AM
Can you "Heel Toe" the car now?
Old 11-21-2010, 06:27 AM
Bill Bess's Avatar
Ya, "Heel & toe" and pointy driving shoes will help. My feet are like trained dogs, they rarely miss the right pedal.
Harrrr!
Old 11-21-2010, 07:16 AM
Cashburn's Avatar
Backdraft Racing Dealer
You can mount existing pedal so it is left or right of the pedal shaft (not centered). That's a quick way.
IT'S NOT REAL. IT'S UNREAL.
VINTAGE MOTORSPORTS
You can't really drive these cars without it
Old 11-21-2010, 07:26 AM
Cashburn, My concern about mounting the pedals as you suggested would not allow tab touching the shaft to be tight enough. With the 2 tabs you are pulling them together against it. If one has wide feet, the stock arrangement of the pedals is not good. Ron
