Old 02-02-2011, 08:25 AM
Cobra Make, Engine: 427
Question pedals adjustable on a BDR?
I was told the pedals are adjustable on a backdraft is that correct?
If so how much adjustment is there?
Thanks
thanks
Old 02-02-2011, 11:17 AM
Which pedal?
Old 02-02-2011, 12:10 PM
Originally Posted by thunderball View Post
Which pedal?
brake clutch gas?
Old 02-02-2011, 01:07 PM
6t8stang's Avatar
Cobra Make, Engine: BDR#436 - 351W - 450HP / 429TQ
There are options for a little adjustment available....both side to side and height:
Heigth adjustment on Brake pedal?
Need to bend brake pedal (tight squeeze)
Brake Pedal spacing from gas pedal
Eric
Old 02-02-2011, 08:05 PM
Cobra Make, Engine: BDR #491, Red with Black Stripes, 438 Windsor by Keith Craft Racing dynoed at 640hp, Street and Race Prepped.
On the clutch and brake there is a set nut on the back of the rod going into the master cylinder in the footbox. You can loosen this nut and then twist the rod in and out to raise and lower the pedals. The throttle does not have much adjustment due to the nature of getting open full throttle.
Good luck, James
Radical Roadsters of Texas LLC
www.radicalroadsters.com
Backdraft Racing Dealer
281-804-5730
Watch out! You may get BIT!!!
Old 02-03-2011, 10:57 PM
Rwillia4's Avatar
Cobra Make, Engine: BDR #455, KC427W, TWM-FI
They're all adjustable, you adjust them with your feet: the right one causes whiplash, the middle one trys to slam your face into the dash, left side makes the engine pur at any speed.Yep all the adjustability you need!!
Old 02-04-2011, 12:18 PM
Yup, what jus bit said. The gas height is adjustable with the throttle cable but be sure to put a stop behind the pedal so you don't over extend the cable linkage. So the answer to your question is yes, exactly which pedal you're talking about requires a different answer.
Old 02-05-2011, 07:38 AM
6t8stang's Avatar
Might sound silly, but you know the driver's seat is adjustable, right?
Eric
Old 02-05-2011, 11:24 AM
snowgoer's Avatar
Cobra Make, Engine: BDR 983 392 430hp/450T, World Class T5
Crap, I always thought that lever was for the ejection seat option.
Old 02-08-2011, 02:58 PM
Jimbocobra's Avatar
Cobra Make, Engine: Backdraft#357, 392CI Ford Racing, 459hp, 455ft/lbs , TKO 500, 3.43 Gears, Ceramic Coated Headers, Victor Jr. 750cfm, 17in Halibrand wheels, Sterling Gray/Silver Stripes, Gray Leather, Nitto NT05
Neutral
OMG, I hope Excaliber doesn't start on the problems with BDR pedals or footbox space. I'd bet he has a statistic about how many posts there are that complain about BDR pedals. Then we will explain that they are adjustable and we'll get accused of being elitist BDR defenders and Cashburn and him might get into a fight.
1/4 mile 11.92@115.6 and 60ft 1.632
Old 02-08-2011, 04:13 PM
Why must you muddy up this thread as well?
Why don't you just PM your concerns to him?
Cashburn's Avatar
Neutral
Nah, you have to get in the ring to fight... he was not even in the arena.
IT'S NOT REAL. IT'S UNREAL.
VINTAGE MOTORSPORTS
Old 02-17-2011, 10:38 PM
now I just wish I could raise the clutch pedal so I don't have to sit as close to the steering wheel and still get full extension,maybe a nice aluminum block put on the pedal.
Old 02-18-2011, 05:30 PM
a mechanic friend of mine came over today and adjusted all three of my petals up about 2 inches, what a difference now I can have the seat back and feel like I'm in a spacious cockpit even with my short legs
