06-21-2011, 06:34 PM
Stolen Avitar
GA
Pushers in a BDR
06-21-2011, 06:54 PM
Cobra Make, Engine: BDR
Looks good, any specific reason you didn't center them on the radiator? (Period correct,preference, etc)
06-21-2011, 07:13 PM
Backdraft Racing Dealer
Honestly I'm not a fan... They actually block and disrupt more air then they flow and hooking them up to the temp sensor can result in them coming on at a bad time like when a kid at a car show is sticking his head in there or your phalanges...
06-22-2011, 04:59 AM
Stolen Avitar
GA
I’ll definitely give you that they don’t move much air. However, I’ve been driving around here a good bit and even with the temps hovering around triple digits there has been no noticeable change in the engine’s temps. Once it gets up to a little over 80c it just sits there no matter whether we’re driving down the highway or sitting at a traffic light. Sides, I’m running a big inch FE with lots of original looking stuff so it’s for the visual impact anyway.
As far as loosing phalanges or little kid’s heads goes, if the wiring is run to Fan2 then they are slaved not only to the temp sensor but to the ignition switch as well. So if the kid (or the owner) comes up missing digits then I have to ask: wtf where they doing in there with the engine running?  AS far as Cobra dangers go, the pipes are more of a threat than the fans by a huge margin.
So quite yer biatchin’ Jay and post some pics of the ones that you’ve done!
06-22-2011, 08:50 AM
Stolen Avitar
GA
If you mean, why not lower, then the answer is that if it were any lower than what it is then I would be pushing the clearance for the oil cooler plumbing. Even though the plumbing isn't quiet done yet I did put the 90 degree elbows in place while I was doing the measurements. There are other issues though. One that you mentioned was originality and that was a consideration. Also, there is quite a bit of radiator up under that sloping area of the nose. This pic shows what I mean about the cooler fittings even though it's not a BDR
06-22-2011, 10:41 AM
Forgot, your chassis is so old it does not have the updated wiring that allows fans to come on when the key is off/out ....
06-22-2011, 10:42 AM
06-22-2011, 11:40 AM
Stolen Avitar
GA
Why Jay, you cut me to the quick.....................
So? I'm slow.
06-22-2011, 03:35 PM
So? I'm slow.
Been so long...
06-22-2011, 06:22 PM
Cobra Make, Engine: Backdraft 879, Indigo Blue / Wimbledon White, 428 Cobrajet, TKO 500
80C? Are you running the stock radiator and fan combo? I just replaced mine with the upgraded system and still am runnning around 90C (vs. 100-105C). The temp is ok now but just wondering how you are running so "cool". What degree thermostat are you using? 160 deg? 185 deg?
06-23-2011, 10:56 PM
La.
Cobra Make, Engine: Waiting to Order a BDR, engine to be a SA C408. TKO to hook it up.
So? I'm slow.
Keep the revs up
Pull a gear .... drop the hammer .... and enjoy the Drive !!
06-24-2011, 07:25 AM
Stolen Avitar
GA
I'm running a 190 Tstat and as far as I can tell that's where it stays all the time. Doing the conversions between C and F with that little gauge is imprecise at best but it never goes all the way to 90C. Stock single fan/radiator and the pushers seem to have had no effect on the temp at all.
Originally Posted by Doug I
Keep the revs up
Yeah, reving an engine. That's something that I normally don't have a problem with. Seems like someone else had THAT problem!!
06-24-2011, 08:30 AM
La.
Should I wash the car ? Still looks a little dirty for being on asphalt
06-24-2011, 03:51 PM
Stolen Avitar
GA
No, remember it's dirty because someone didn't stay ON the "ass-felt"! LOL You know of course that hardly anyone reading this will know what we're on about.
06-24-2011, 05:03 PM
La.
At least she's cleaner (faster too) than her sister on the left coast  Sometimes they needed GPS ....
