Old 09-01-2011, 09:26 AM
Default Gas Tank Leak & Removal?
Hello guys,
My car is a Backdraft RT3 #755. I notice the other day that I had a small leak from my Gas tank. 1 drop every 10minutes. And also it was random. So i lift the car and it was impossible to take the tank out to see it .
I put my fingers at the top of the tank - and I felt it wet, so I took my cellphone and I managed to take 1 image that shows the problem. Also I found a piece of seal very close to the golden area. I am positive it belongs to the seal.
So how can I access the top part of my tank where the fuel level sender is. I think the seal there is damaged and is leaking. I am thinking to cut an opening from the top. But I am sure there must be away to take the tank out?
What option do I have?
Thank you - Andronikos,
Old 09-01-2011, 09:51 AM
Cashburn's Avatar
Backdraft Racing Dealer
Tank unbolts from the bottom...
IT'S NOT REAL. IT'S UNREAL.
VINTAGE MOTORSPORTS
Old 09-01-2011, 10:07 AM
Hi Jay, yes but from the passenger side is a hose that sticking out, and hits the frame. Are you sure we can remove it from below?
Old 09-01-2011, 11:36 AM
Cashburn's Avatar
Yes, remove hoses, unbolt and shift/tip is to drop out.
VINTAGE MOTORSPORTS
Old 09-01-2011, 11:54 AM
Thank you - I will try it tomorrow. Do you know what is that seal? Is it form the fuel level sender? If yes should I order a new sender then? I have to admit that fuel gauge does not work very accurate on my car.
Thanx - Andro,
Old 09-01-2011, 03:28 PM
I would hang a few "No Smoking" signs around as well...
Old 09-02-2011, 09:39 AM
Cobra Make, Engine: Backdraft #90, 351w,Tremec 3550, SB100 SOLD
Yeah, and maybe disconnect the battery first.
Old 09-02-2011, 09:51 AM
All ok, i fixed it guys. Thanx
