Like Tree1Likes
  • 1 Post By Cashburn
Old 08-06-2013, 07:29 PM
Cobra Make, Engine: Backdraft 347
Default steering
3rd cobra 1st bdr can is it possible to bring steering wheel closer to driver with out buying new wheel just fitted wheel from my old car is the colulm able to moved up
Old 08-07-2013, 01:00 PM
Wow 60 looks and not 1 reply so it's try anybody who owns a backdraft
F does know there car or how it works as long it is shiny and has a roush engine
Old 08-07-2013, 01:49 PM
I have an early model car and haven't had mine off in a few years but I do think it is possible. You have to remove the steering wheel from the hub then there is a u-clamp under the dash that will have to be loosened and then in the engine compartment, the shaft is actually a tube within a tube that rides on a bearing. You would have to remove the small bolt that is bolted through these tubes, pull the shaft out to the desired position you want the wheel, reposition the inner bearings (be careful as these are fragile) and then re-drill the hole for the pass through bolt.
Not sure how this will affect your blinker or if the wiring is long enough.
Old 08-07-2013, 02:52 PM
Cashburn's Avatar
Backdraft Racing Dealer
Great way to get started here
bwcobra15 likes this.
IT'S NOT REAL. IT'S UNREAL.
VINTAGE MOTORSPORTS
Old 08-07-2013, 06:27 PM
Thanks true007 u 2 cashbum
Old 08-07-2013, 07:04 PM
Cashburn's Avatar
No prob bieberstev69.
VINTAGE MOTORSPORTS
Old 08-07-2013, 08:07 PM
Cow bum u a polisher if not help out with a steering problem or keep it shut
