Like Tree5Likes
Old 09-08-2013, 10:11 AM
Mark Brye's Avatar
Default Burping Cooling System
Hi Guys,
I am having problems getting the air out of the cooling system after flushing the system. Could you guys give me a hand on the instructions for burping the air out of the cooling system on the BDR. Being the BDR only has the overflow tank to fill by, there must be a trick to this that I am not getting....You would think that an easy task like this would not give me problems...
Thanks!
Old 09-08-2013, 01:25 PM
Cashburn's Avatar
Backdraft Racing Dealer
Park it on incline, nose up and let it run with cap off. We use a pressure bleed system now but that method worked for our first 6 years.
JBCOBRA, BDR0572 and Ozzie Goat like this.
IT'S NOT REAL. IT'S UNREAL.
VINTAGE MOTORSPORTS
Old 09-08-2013, 02:03 PM
Mark Brye's Avatar
Thanks Jay, I will give that a try. I had the front up on jack stands but did not have the engine running. I will give that a shot. Might borrow the neighbors driveway being it has a little more incline.
Old 09-08-2013, 07:06 PM
Cobra Make, Engine: SP
Lisle 24610 Spill-Free Funnel : Amazon.com : Automotive
it works very well.
joe
Old 09-08-2013, 07:17 PM
Neutral
Jays is dead on. it works every time.
MP
BDR0572 likes this.
Old 09-08-2013, 08:01 PM
MP
It's Joey.S LOL
Old 09-09-2013, 05:51 AM
I say take Jay & Joey.s's responses and combine them. At least with Joey.s's link you will not lose as much coolant or whatever mixture you are running.
Terry
Old 09-09-2013, 06:06 AM
The funnel way is the easiest. Or cut the bottom of a 2 litre Coke plastic bottle, use a hole saw cut the top of a old radiator cap, and glue, or silastic the top of the Coke bottle into the radiator cap.
JD
Old 09-09-2013, 08:51 AM
eschaider's Avatar
Mark,
This is the fastest, most reliable way to fill a difficult to fill/burp cooling system I have found. It is simple, quick and there are no air bubbles left - anywhere.
click here => Vacuum Fill System
Ed
Old 09-09-2013, 10:28 AM
i used loosen the temperature sending unit on the intake manifold during the intial fill. may work the next time.
Old 09-09-2013, 05:47 PM
The funnel is also a great way to check for head gasket leaks. Any bubbles showing in the funnel is usually a head gasket leak.
JD
Old 09-09-2013, 06:51 PM
The "in garage" method is to wedge two asprins between the thermo disk and seat. The themo will stay open long enough to purge the system.
Works every time for me...
Old 09-09-2013, 07:04 PM
Mark Brye's Avatar
Thanks guys. I think I got it. I made a funnel last night out of a two liter. I think I got the air out. I also had the front end way in the air.
I think I am going to try and get one of those vacuum units or the funnel with the correct fittings for next time. I think that will save me some time and some of the mess that I made
Old 08-28-2018, 05:46 AM
Cobra Make, Engine: Backdraft SBF-302
Couple questions for those that have done this:
1) how high does the front end need to be ? I used 1.5" blocks, let her run for a while (the fans were on); it never filled the funnel, even after 15 minutes
2) with air in system, can it run more hot than usual ?? I'm not boiling over, but she used to run at 90-degrees and last night was running closer to 100
Thanks for any thoughts...
Old 08-28-2018, 09:27 AM
Cobra Make, Engine: '65 Shelby Cobra, '66 Shelby GT350's
Originally Posted by eschaider View Post
Mark,
Ed
Fastest, easiest, with the greatest piece of mind of the job done right.
~ Steven
6S1806, 1966 Shelby GT350 B/P Race car.
6S246, Shelby GT350 "carryover"
6S1745 Shelby GT350
Old 09-17-2018, 10:05 AM
In the past with a C3 Corvette that I owned for over 30 years, had to go through the burping process since engine sat taller than the radiator in flushing radiator process.
Not sure the issue with a Backdraft as the water tank is higher than the engine block. Just did the first flush on a pre-owned Backdraft purchased five months ago. Did jack up one side of the car to get a little height, pulled plug, drained, installed plug, filled with distilled water plus the pink Water Wetter.
The only issue I had was stupid me, tried to tweek the plastic drain plub with a short box end wrench and broke the drain plug. Came out extremently easy with a small easyout but had to wait on a drain plug from Iconic.
Car runs cool as a cucumber in Texas heat- right at 180 degrees in 100 degree days and sitting at red lights. Now the AC in the car doesn't work with a darn. :-)
Old 09-17-2018, 10:33 AM
BMW Part https://www.ecstuning.com/b-genuine-...g/17111719384/
Mfg Part #
17111719384
I see VigiLink redirect is active again on the Club Cobra website. You may have to look for the link to ECS Tuning once redirected by Vigilink,
Old 09-17-2018, 01:06 PM
cycleguy55's Avatar
Mfg Part #
17111719384
You can disable VigiLink in your desktop browser - when it hijacks links look for the link that says "Why am I seeing this?" Click on that link and it will give you an option to disable VigiLink. I did that and the link hijacking has done away.
You can go here and disable VigiLink: https://www.viglink.com/opt-out/
Brian
Old 09-18-2018, 12:35 PM
Cobra Make, Engine: Backdraft #1333, Smeding 427
Pat it firmly on the valve cover while rocking back and forth in a gentle motion.
spdbrake likes this.
Old 09-19-2018, 09:42 AM
I drill a little hole in the thermostat and install it hole side down. Really helps in addition to having the car on an incline.
