November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 09-23-2013, 09:41 AM
Cobra Make, Engine: BDR, 302
Default 15" Knock offs
Does anyone have a source for 15" knocks for an early Backdraft? Vintage has a special going on and indicated these would work. Any specs on back spacing for 15x8 and 15x10? Thanks.
Old 09-23-2013, 10:23 AM
phattyhales's Avatar
Kirkham uses Trigo. I imagine they are the same or very similar. Halibrand and Vintage Wheels also make Cobra style wheels.
Old 09-23-2013, 12:52 PM
rodneym's Avatar
Full Blown Member
Premier Contributor
Halibrand is making Cobra wheels again?
rodneym
Old 09-23-2013, 03:07 PM
I thought they were but I couldn't find any on their website (which is terrible btw!) so I guess not.
Old 09-24-2013, 06:25 AM
6t8stang's Avatar
Cobra Make, Engine: BDR#436 - 351W - 450HP / 429TQ
If your name accurately depicts your build number (226), don't you have 5 lug and not knock offs?
Eric
Old 09-24-2013, 07:03 AM
lovehamr's Avatar
Stolen Avitar
Posted on BDR Boys as well, this is from BDR1:
"... A BDR requires a 4 1/2 backspacing on a front 8 inch wheel in 15 inch. This is generally not a problem in knock off wheels. The problem is the rear wheel. In a 15 we use a 15 by 10 with a 5 3/4 backspace. As far as I am aware there are no 15 inch knock off's with the backspacing ..."
I had been talking with 2 vintage wheel companys about this issue but I never really got anywhere. Another thing to keep in mind is that our cars have 5 drive pins on a 120mm bolt circle wich is apparently close enough to use a chebbie 4 3/4" BC.
Old 09-24-2013, 08:30 AM
I just got info from Vintage Wheels that their wheels will fit. They have the 5 x 120mm bolt pattern and proper back spacing for 15x8 and 15x10 wheels. Will be ordering soon.
Yes, I do have 15" bolt ins and that why I wanted to go to knock offs.
Old 10-01-2013, 07:31 PM
IMLost's Avatar
Cobra Make, Engine: BDR #178 United Speed World Special
Wouldn't now be a good time to think about if you are buying to go to 17's?
Doing and driving what other people dream about!
Old 10-24-2013, 06:43 PM
Dinobyte's Avatar
Cobra Make, Engine: Backdraft #395 from Vintage Motorsports; Valley Ford Specialist 487 FE with a TKO600
I run 15's from Vintage...work just fine.
