Old 01-31-2014, 10:17 AM
Smile Battery location BD. 302 Ford
Taking delivery of a new one...1263.. With a Ford racing 302/345.Never took time to locate the battery...duh.Any help on this be appreciated,as well as problems concerning access and servicing.Thanks!
Old 01-31-2014, 10:42 AM
Cobra Make, Engine: BDR, 302
Mine is an early BDR which has the battery located in the middle of the trunk right up against the bulkhead. I think later models had the batteries relocated. Not sure where.
My battery is easy to swap out.
Old 01-31-2014, 02:37 PM
itstock's Avatar
Gold Star Contributor
Drivers side trunk under the rear most panel partially sunk in to floor. Extremely easy to access/replace.
Battery
under this panel
Old 01-31-2014, 08:37 PM
Cobra Make, Engine: Backdraft, 302, Tremec 3550. #038
No way !!! That's a motorcycle battery. Tell me their not putting these in the cars instead of car batteries. I would imagine that battery would be hard pressed to turn over a high compression engine. Unless that's a bad angle or is it photoshopped?
Kids in the backseats cause accidents, accidents in the backseat causes kids ! Good reason to get a Cobra !!!
Old 02-09-2014, 01:54 PM
PANAVIA's Avatar
I personally prefer the PC925 from Oddesssy -- small works great , saves weight.
Old 02-26-2014, 05:04 AM
tamanaco's Avatar
Cobra Make, Engine: BDR #260 w/ 347 stroker, Canfield 195 cc heads, prosystems carb on a VicJr, Comp roller cam
Smile
Originally Posted by mole21401 View Post
taking delivery of a new one...1263.. With a ford racing 302/345.never took time to locate the battery...duh.any help on this be appreciated,as well as problems concerning access and servicing.thanks!
:jekylhyde
