Old 04-25-2014, 08:57 AM
Cobra Make, Engine: Backdraft 347
Default Engine swap
Thinking of swapping out 302 with 340 hp to 351 w stroker ? Will I be able to use the same headers or do I need to get new ones
Old 04-25-2014, 09:04 AM
Texasdoc's Avatar
Probably not. Since the 351 is wider and taller, that will push your pipes up and out. You will need different headers to keep the pipes in the same place.
Old 04-25-2014, 09:35 AM
Cashburn's Avatar
Backdraft Racing Dealer
You will use the same headers. You just will make adjustments in the mounting height of the motor and may have to trim the sidepipe opening differently depending on the build era of your BDR.
IT'S NOT REAL. IT'S UNREAL.
VINTAGE MOTORSPORTS
Old 04-25-2014, 01:52 PM
Thanks guys yes thinking maybe stroke 347 then no pipe problem
