Old 10-14-2014, 03:34 PM
Default No Power
Still have no power at key traced wires back to starter all good but no power at key no lights no gauges any ideas please
Old 10-14-2014, 03:46 PM
mln385's Avatar
Cobra Make, Engine: BDR
Have you checked the master switch? Depending on year it is behind the passenger seat or on tranny tunnel.
Old 10-14-2014, 04:04 PM
Yep have power to starter but none to no where else
Old 10-14-2014, 04:23 PM
mln385's Avatar
Have you checked the fuse panel in passenger side kick panel?
Old 10-14-2014, 05:06 PM
Yep checked all fuses
Old 10-14-2014, 05:48 PM
MOTORHEAD's Avatar
Steve: there should be a wiring diagram in your manual. I'm looking at one now. It doesn't show the real wiring to the starter. I think the + wire from the master sw first goes to the starter solenoid on the starter itself. At that connection there should be a smaller wire that feeds everything else. You have to get under the car to access it.
"When Injustice becomes Law,
Old 10-15-2014, 06:41 AM
Yep done that have power there but from there to the key pulled all convections and still no power no lights wipers turn sig nothing but thanks for helping
Old 10-15-2014, 07:50 AM
Ron61's Avatar
I am not familiar with the Backdraft wiring but does your dash have a plug in that all the wiring goes through like some of them do? If you have pulled the wires physically to the key switch then whichever one supplies the power must be open inside the insulation. It sounds as if you have checked all of the most logical places. Also on your master switch, did you look to make sure one of the wires hasn't came off? I had that happen once on my Cobra and I changed the type of connector it used.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
Old 10-15-2014, 07:56 AM
MOTORHEAD's Avatar
Steve: The wiring diagram is pretty poor in the area of the primary power distribution.
The starter motor(large)terminal should be hot whenever the batt sw is on. The rest of the electrical system is fed by a smaller red wire from that starter terminal to the fuse/relay box under the left side panel, and also to the ign sw. , so if you have voltage at the starter solenoid, but not at the fuse box or ign sw, then that wire is open. It could have broken away from the terminal where you can't see it, or it may be a bad connection at the fuse box end. I remember there was a harness connector on the pass side in the engine compartment, fwd the firewall, but don't remember if the primary power went thru it, or if it was just the fwd lights, etc., but worth checking.
Ted
Old 10-15-2014, 08:37 AM
mln385's Avatar
Run a ground to the battery and your tester, then check all known areas for +12vdc.
You may have +12VDC but if you lost your ground no peripherals will work without the return path.
Old 10-15-2014, 09:21 AM
Yep have all wiring out unwrapped and going though them one at a time thanks Steve H
Old 10-15-2014, 10:12 AM
MOTORHEAD's Avatar
Steve: You should have a PM
