Old 03-22-2015, 09:15 AM
tamanaco's Avatar
Cobra Make, Engine: BDR #260 w/ 347 stroker, Canfield 195 cc heads, prosystems carb on a VicJr, Comp roller cam
Default Rack and pinion assembly is from what car
Does anyone know what the rack and pinion was from for cars built in 2006?
did some searching found Toyota right hand drive flipped over? if so...what year, model,???
whating to have less turns lock to lock...and looking at Unisteer electric power steering.
Thanks!
BDR#260...21.6K miles logged as of 4/2018
www.motorheadsohio.com We are an engine machine shop, specializing in crankshafts!
47 years of doing business an going strong! stop on by for a personal tour of the shop
Old 03-22-2015, 10:39 AM
Grey 65's Avatar
Thanks!
Put a BMW Z3 rack in the car... 2.7 turns lock to lock....
Kevin....
Old 03-23-2015, 06:04 AM
tamanaco's Avatar
Kevin....
So, this was a bolt in swap? or modifications required?
Old 03-23-2015, 01:22 PM
Grey 65's Avatar
Backdraft sells a kit... Check out their parts website it is like $1,350.. But you still have to provide a pump.... I would go with a KRC racing cast iron pump and the #6 valve.
Kevin...
Old 04-04-2015, 10:41 AM
tamanaco's Avatar
I want electric power steering from unisteer. i need a rack n pinion that is a quick ratio that will fit into a BDR car. So, i'm curious whos' rack BDR uses. Is it a bimmer Z3?
