Like Tree14Likes
  • 13 Post By MOTORHEAD
  • 1 Post By fordracing65
Old 06-14-2015, 09:29 AM
Cobra Make, Engine: Backdraft - Coyote
Default The Annoying Unwanted Sounds Thread
I thought it would be beneficial to start a thread for BDR owners to share their thoughts on how they remedied unwanted sounds from their cars. Some examples are rattles, squeaks, thuds, and shimmy's over bumps. Side pipes can only mask so much of the annoyances and it eventually comes down to correcting the mistakes manually. I search the forum for answers from time to time but only come up with answers for half of the common problems owners complain about. Since these answers are sporadically distributed throughout multiple threads I thought it would be nice for BDR owners to stop at one place for the fixes. I realize these cars aren't meant to ride like a Lexus but obvious problems have been solved by many owners with great, noticeable results. Please don't feel an answer will be taken as too "anal" or "overkill". We all want to know what you know.
Thanks in advance.
Old 06-14-2015, 09:57 AM
Mark Brye's Avatar
My door had a terrible squeak. I found that it was the foam door seal rubbing against the door. I took a rag with some s303 on it and wiped the seals and six years later the super loud squeaking is gone. I also found a coin from South Africa behind door panel that rattled. Fixed a squeak in rear suspension that was the rear spring rubbing in lower spring bucket. Just rotated spring a little and all is good. Hood prop rod rattled in its mount. I used a dab of liquid rubber there. Been annoying sounds free for last six years but did take a couple years to find them all.
Old 06-14-2015, 10:53 AM
Average Guy
I don't have a BDR, but I had an annoying rattle whenever I hit a bump. I couldn't seem to locate it. One day I simulated a bumpy road by hitting the tires with a rubber hammer. Sure enough, when I hit the RF tire, I heard the noise, this time right in front of my face. One of the vanes in the side louver had gotten loose. Easy fix, problem solved.
Old 06-17-2015, 06:34 AM
Cobra Make, Engine: Backdraft #832
I purchased and installed a fire extinguisher between the seats. While driving the car I found the pin that holds the handle closed had a bad rattle. I took some heat shrink and covered the pin. This stopped the rattle. Quick and simple fix.
Old 06-17-2015, 04:14 PM
MOTORHEAD's Avatar
Driving home the other day, I punched it to pass a truck, and was met with a extremely loud howling noise. Got home and determined the problem ! left her home the next time out !!!!
Ron61, FatBoy, cab and 10 others like this.
"When Injustice becomes Law,
Old 06-19-2015, 08:24 PM
Cobra Make, Engine: Backdraft #1333, Smeding 427
that was funny
Old 06-19-2015, 10:49 PM
fordracing65's Avatar
A rattle, how could it be, lol...they are kit cars...all of them rattle...
Bartruff1 likes this.
PRIDEnJOY
Old 06-20-2015, 12:17 AM
FatBoy's Avatar
I think that's the point, they don't have to. With a bit of care and perseverance they can be fixed.
My Kirkham is rattle free on all but the very worst surfaces.
Paul
Old 06-20-2015, 12:46 PM
LMH's Avatar
LMH LMH is offline
I had a terrible squeal from a now sold FFR but after she got out of the passengers side, the noise went away!
Alba gu brąth
Old 06-21-2015, 06:11 AM
BADSN8K's Avatar
Cobra Make, Engine: BD 1445 Coyote TKO 600 3.91
place two packs of sugar.... that will work every time......
Old 06-22-2015, 05:14 AM
Bill Bess's Avatar
Simple to fix.....put the cobra on a trailer and pull it with a Buick.
Smooth and quiet, plus a nice soft ride.
HEEEE!
Failure is not the outcome, it's not trying.
Old 06-28-2015, 12:23 PM
the side pipe rattle is awful. Backdraft needs to go back to the vendor they used pre 2012, these new pipes sound like a bucket of bolts
Old 06-28-2015, 06:39 PM
Cobra Make, Engine: StreetBeasts, 331 Stroker
Not a particularly elegant solution, but I have a set of shell valley side pipes and they began to rattle on account of something coming loose within the inner baffled system. I drilled about 8 1/4" holes along the bottom of the pipe where they would not be visible, and pumped the pipe with an entire large tube of high-temp silicone. Let it sit of over a week. This did not resolve the mechanical source of the rattle, but it certainly reduced it by 70-80%.
