09-19-2015, 07:26 AM
LSD Options
Where is the best place to source a 3.46 limited slip diff?
09-19-2015, 07:31 AM
CC Member / Sponsor
UT
09-19-2015, 08:00 AM
09-19-2015, 10:20 AM
Backdraft Racing Dealer
Only place I would recommend is Diffsonline. We tried several other builders and they never could come close or have any consistency.
09-21-2015, 06:58 AM
Diffsonline or if you have some local racers that race E36's you can get the guy they use to build theirs to build yours. I have a 60% locked 3.46 diff in my car that handles more abuse than I would guess any other BDR out there...
Kevin
09-21-2015, 09:15 AM
+ 1 diffsonline.
09-21-2015, 02:10 PM
Well, that seems pretty unanimous. Thanks for the replies!
09-21-2015, 03:54 PM
09-21-2015, 05:21 PM
Diffsonline supplies Turner.
09-21-2015, 05:30 PM
My friend is trying to talk me in to going with the Quaife, and although he is probably right, I have to admit that is some serious sticker shock. I was looking at doing a 60% lock, and might still go that route.
Kevin
09-22-2015, 04:56 AM
I am surprised they let you run the track without arm restraints in an open cockpit.
09-22-2015, 06:50 AM
I am pretty hard on the car even though the above events aren't road racing.
I wasn't trying to imply no one else abuses their car.. I was talking stresses to the diff. I put a lot of load on one wheel forcing one side of the diff to bare almost all the load...
Check out BimmerDiffs, this is where I got my parts to build up the diff.
I looked at OS Giken and Quaife... I then talked to a lot of E36 racers and they all said... Just go with a 60%....
Kevin.....
09-22-2015, 09:03 AM
I have arm restraints on, they are the Simpson ones that go right above my elbow. You should be able to see them if you have vid quality to hd. I pulled up and the guy teching told me I was going to hate him because I couldn't run without arm restraints. I had them shoved in the helmet and the only reason I had them was someone on this forum said they couldn't run without them.
09-22-2015, 09:05 AM
Kevin.....
Thanks for the advice and replies. You are tipping my mind back to the 60.
09-22-2015, 01:02 PM
From the diff master:
"I like to play with the ramp angles a bit for more lock to get there. I hate more preload as it drags wheels. I would do a 3 disc setup with 35/60 ramps instead of the 45/45 angles. I would set the preload in the 40 range so it behaves normally most of the time until he hammers it."
