| S |
| 1 |
5 |
| 8 |
12 |
| 15 |
19 |
| 22 |
26 |
| 29 |
30 |
31 |
3Likes
Post By cycleguy55
Post By Kobura
Post By jeffnolan
10-30-2015, 06:01 AM
Changing headlight bulb
Thinking about upgrading the H4 bulbs in the headlamps. Can anyone provide any pointers on how to access the bulbs? Is it a pain?
10-30-2015, 10:41 AM
SK
It's probably no different than most: - Loosen the trim ring retaining screw and remove the trim ring
- Remove screws holding headlamp retaining ring (3, I believe)
- Remove headlamp retaining ring
- Pull out headlamp assembly and remove electrical connector from bulb or headlamp
- Release bulb retaining spring from catches
- Remove H4 bulb
- Install replacement H4 bulb. Note: Do not touch glass surface of bulb with fingers or anything greasy. If you do, clean thorougly with 99% Isopropyl alcohol or mineral spirits using a clean cloth or swabs. Any residual oil or grease WILL cause bulb to fail prematurely!
- Put bulb retaining spring back in place and ensure spring 'legs' are thoroughly locked in place
- Attach electrical connector and place headlamp assembly in bucket, aligning protrusions on rim of headlamp with recesses on bucket
- Please headlamp retaining ring in place and insert retaining screws, taking care to ensure headlamp is properly seated before tightening all 3 screws
- Place headlamp retaining ring in place, insert and turn retaining screws a couple of turns.
- Turn headlamps to 'On' position and confirm headlamps are working.
- Check to ensure headlamp is properly seated, then tighten all 3 retaining ring screws.
- Place headlamp trim ring in place, hooking top end on catch.
- Insert trim ring screw and tighten.
- Remove finger smudges with a clean cloth
- Step back and admire your work
- Go for a drive - day or night.
- Celebrate a task well done with a beverage of your choice.
- Brag about your mechanical prowess at the next Cars & Coffee, Show & Shine, etc.
Brian
10-30-2015, 11:22 AM
CAVEAT: You can remove the ring without messing with your adjustment; look at the ring and there are angled slotted openings and only one (i think) screw that actually has to be removed apart from the one under the trim ring that lets it fall out.
Study it and it will make sense.
Superformance 1764
Built 427W
Aiken SC USA
10-30-2015, 11:24 AM
Oh one more thing i upgraded to the Lucas triangle braced H4 lights, they also have a neat little "City" light bulb which lights up the lamps dimly for tooling around town in brightly lit areas without blinding everyone...Sort of a sexy look.
Superformance 1764
Built 427W
Aiken SC USA
10-30-2015, 11:52 AM
Great info. Thanks !
10-30-2015, 12:29 PM
CA
Cobra Make, Engine: Backdraft RT3 #1133, Ford Racing 306
Looks like a fun way to have a bonding experience with your car. Sure beats lifting the car and crawling under it.
10-30-2015, 12:52 PM
Question: How many forum members does it take to change a light bulb?
10-30-2015, 01:02 PM
SK
All that bending and stooping could be hard on the back. Perhaps the best way is to get the car up in the air so the headlight is at waist height or even eye level. Yeah, that's it...
Brian
10-30-2015, 01:12 PM
Ca
That depends on whether the light bulb is an original or replica.
Original, one.
Replica, 1266.
Jim
10-30-2015, 02:55 PM
MI
Cobra Make, Engine: Backdraft RT3GT, Arancio Argos/Black Magic, Coyote XS, T-56 Magnum
Go LED and never look back. The light output is ridiculous.
10-30-2015, 09:45 PM
Cobra Make, Engine: Backdraft #1333, Smeding 427
I replaced my headlights with LEDs. Expensive but worth it, a bright white light that is far superior to H4 replacement bulbs.
10-31-2015, 04:54 AM
Is this a direct replacement LED bulb for the standard H4 bulbs or is there more involved?
10-31-2015, 04:17 PM
complete replacement.
[ame="http://www.amazon.com/Philips-Round-LED-Headlamp-Pack/dp/B00H8BWEGM/ref=sr_1_3?ie=UTF8&qid=1446333290"]Amazon.com: Philips 7" Round LED Headlamp (Pack of 1): Automotive@@AMEPARAM@@http://ecx.images-amazon.com/images/I/51BcpjXFlSL.@@AMEPARAM@@51BcpjXFlSL[/ame]
11-01-2015, 03:54 AM
Jeff any wiring work involved or is this plug and play? Pricey but looks well worth it.
11-01-2015, 07:09 AM
Takes about 5 minutes each side. 1 screw to remove the trim ring, 3 more for the retaining ring, unplug old, plug in new, put everthing back together.
Totally worth it. If Carroll Shelby had LED lighting in the 1960's, he would have used it.
11-01-2015, 08:26 AM
Thank you sir !
