Like Tree6Likes
  #41 (permalink)
Old 03-20-2017, 04:34 PM
I never could figure it out, nor could the shop. I just live with it. No adverse performance. I havent put many miles on in a year though. I had back surgery.
  #42 (permalink)
Old 03-20-2017, 04:57 PM
Well that's a piss-poor shop that probably didn't want to go to the trouble of running voltage drop tests along the circuit, both on the hot side and the ground side. If you have normal voltage at the alternator/battery, and not-normal voltage a distance away, then you "walk the circuit," while it's under load, looking for the spot of increased resistance, with your ten dollar VOM, that will have a voltage reading when you bracket it with your probes. Voltage doesn't just vanish and fly off like Tinkerbell. It's slipping away because of high resistance, like a bad crimp, poor soldering, loose ground, or a broken wire inside the insulation. The only way you can test for it is when it's under load, and it takes a little patience. But it's not brain surgery.
Jaydee likes this.
