-   BackDraft Racing --- (http://www.clubcobra.com/forums/backdraft-racing/)
-   -   Fun times today... (http://www.clubcobra.com/forums/backdraft-racing/135788-fun-times-today.html)
eunosracr 02-05-2016 09:29 PM
Fun times today...
So I get in the cobra to start it and as I turn the key and push the ignition button the starter goes crazy and keep on running. I pull the keys out of the ignition and the darn thing keeps running. I finally decide to pull the battery cable to
Kill the starter which works. Get car towed to the shop, prognosis is starter is dead solenoid got stuck which made stater keep running . How do I fix this in the future without needing the dreaded tow. New stater going in now. Would hitting the starter with a hammer fix this?
Jaydee 02-06-2016 12:37 AM
Hitting the solenoid could unstick it. If the solenoid is stuck because of corrosion or grease build up. A new starter shouldn't have that problem. It is unusual to get stuck like yours. I have seen it once and the starter was glowing red and the battery almost melted, because they didn't disconnect it. Sometimes the solenoid return spring breaks due to rust. Glad that you have a cutout switch.
JD
Ron61 02-06-2016 01:45 AM
That could have damaged the battery also, so be on the look out for that. You said that you pulled the battery cable. You should install a battery cut off switch which you can just turn and it cuts off all power to everything which is much faster and easy than taking a battery cable off. I saw one solenoid stick because of the contacts melting and sticking together but this was one of the old original type. Hitting the starter with a hammer in this case would not have helped as it is going to try to run as long as there is power to it.
eunosracr 02-06-2016 03:26 AM
Jesus battery cut off switch ! I did not even think of that. In my haste I ran and pulled the battery cable not thinking that I have a battery kill switch. Lesson learned. Keep in mind this starter is about 7 years old at this point.
eunosracr 02-11-2016 09:22 AM
Quick Update: She is back on the road with a new starter. While at the shop I had them install Armando's low profile oil pan which i had sitting in my garage for months. Maybe it is just me but the car seems to rev more freely. Would this have anything to do with the oil pan and or its windage tray?
my427cobra 02-11-2016 01:26 PM
Hi all. There was a good thread a few years ago about "quality" solenoids. I tried using "period correct", "concors" FOMOCO solonoids from all of the big three Mustang parts houses and they all failed as described above. One after only a few uses.
Finally bit the bullet and got a real Ford unit. No problems since.
Greg
