Like Tree5Likes
  • 3 Post By Tommy
  • 1 Post By Late Apex
  • 1 Post By picross
Old 02-21-2016, 04:21 PM
Default Brake lights started flaking out
So the brake lights started flaking out today. I have LED bulbs but they only work sometimes when i press down on the brake pedal. Should I just bite the bullet and replace the switch that goes to the master cylinder? I doubt its the bulbs since both sides are acting exactly the same from working, to dim, to flashing, to not working at all. Any suggestions?
Old 02-21-2016, 04:28 PM
mln385's Avatar
Cobra Make, Engine: BDR
Check the connection on the switch, might be loose. It is a common problem on these cars.
Old 02-21-2016, 04:37 PM
Cobra Make, Engine: johnex
Try a meter or test light on out put side of switch. See if it's switch or jump the switch see if they work
Old 02-21-2016, 04:40 PM
Thanks guys. Will try this and report back.
Old 02-21-2016, 04:54 PM
Tommy's Avatar
Bad and intermittent grounds are very common on fiberglass bodied cars. If both brake lights are grounded through a common wire, that could be it. A quick test is to run a temporary jumper wire from the brake light fixture ground to a known good ground. If that makes the problem go away, you have identified the source of the problem.
mln385, twobjshelbys and eunosracr like this.
Tommy
Previously owned EM Cobra
Old 02-22-2016, 10:37 AM
Cashburn's Avatar
Backdraft Racing Dealer
Take the two wires off the switch and connect them. If it works perfectly than it's the switch.
IT'S NOT REAL. IT'S UNREAL.
VINTAGE MOTORSPORTS
Old 02-22-2016, 11:46 AM
Jay- Do you mean with a jumper wire? Also the brake lights do seem to work if i really press down on the pedal. Does this sound like the symptoms related to a bad switch?
Old 02-22-2016, 01:11 PM
twobjshelbys's Avatar
Check grounding. The tail light is grounded by a wire to the chassis somewhere. Try attaching an alligator clip lead set to the light and a chassis ground. At a minimum clean paint off the chassis area where the ground return is connected to the frame.
CSX4005LA
Old 02-22-2016, 01:17 PM
Tommy's Avatar
The switch closes the circuit (i.e., connects the two wires attached to it) when the pressure is high enough. Connecting the two wires together either with a jumper or by disconnecting them from the switch and pressing them together will bypass the switch and should turn the brake lights on. If that solves the problem, then your switch is the likely problem.
Tommy
Old 02-22-2016, 02:18 PM
Thank you Tom !
Old 02-22-2016, 02:53 PM
Cobra Make, Engine: 1963 Corvette Grand Sport Coupe. ZZ502FI. 502 HP
With only 645 miles on my new BDR Cobra, the left brake light went out last week. On inspection of the bulb it was black and done. Right side ok. Ordered GE 12v 5w brake bulbs from Amazon, 2 to a pack, and they work great and are brighter than whatever brand the factory uses too. Hope you correct the problem that easy.
eunosracr likes this.
Your ride should not be to get from point to point. It should BE the point!
Old 02-25-2016, 07:53 PM
Problem solved by replacing the switch. Cheap and easy fix. I bought an extra one just in case.
Old 05-09-2016, 07:46 AM
Cobra Make, Engine: Backdraft cobra, Ford motorsports 302, holly carb
There is also a heat shield you can buy to help keep the switch on the master cylinder from failing (too close to the headers apparently). I have an early backdraft (#157) and it did not come with the shield - my switch failed also and i put the shield on. I ended up also installing a mechanical backup as well just to be safe.
Old 05-14-2016, 07:02 AM
tamanaco's Avatar
Cobra Make, Engine: BDR #260 w/ 347 stroker, Canfield 195 cc heads, prosystems carb on a VicJr, Comp roller cam
the switches used on BDR cars have been failing since the 1960's when it was very common brake switch in production cars...Ford's i think. They just failed! the best solution is a mechanically actuated switch by the movement of the brake pedal...you'll never look at it again!
BDR#260...21.6K miles logged as of 4/2018
www.motorheadsohio.com We are an engine machine shop, specializing in crankshafts!
47 years of doing business an going strong! stop on by for a personal tour of the shop
