Like Tree1Likes
Old 07-17-2016, 04:44 PM
tamanaco's Avatar
Cobra Make, Engine: BDR #260 w/ 347 stroker, Canfield 195 cc heads, prosystems carb on a VicJr, Comp roller cam
Default street tire launch at a sticky drag strip
OK...just broke something in the diff or half shaft on my #260 BDR car. 3.91 gears posi diff, 295 50 15 cooper cobra tires, 3000 rpm launch, on a T5WC trans. getten wheel hop, like 3 to 4 chirps before it hooks, 1.8XX 60 foot times. Got the Bilstien shock and standard BMW rubber in the rest of the car. Wheel hop did seem real bad...but it broke. 390 rwhp on a 347 cid stroker. What will fix the wheel hop? BTW...11.970 @ 117.4 MPH
also shifting to second...no hop just tire spin! ditto 3rd
Zeke likes this.
BDR#260...21.6K miles logged as of 4/2018
www.motorheadsohio.com We are an engine machine shop, specializing in crankshafts!
47 years of doing business an going strong! stop on by for a personal tour of the shop
Old 07-17-2016, 04:47 PM
fordracing65's Avatar
Cooper tire. Seriously. Try a real tire. Those are the same tires I use on my work van.
PRIDEnJOY
Old 07-17-2016, 08:18 PM
tamanaco's Avatar
Originally Posted by fordracing65 View Post
cooper tire. Seriously. Try a real tire. Those are the same tires i use on my work van.
Really...
Old 07-17-2016, 08:52 PM
Originally Posted by tamanaco View Post
Really...
Ya. Really. Your tires have an 85 mph speed rating.
PRIDEnJOY
Old 07-17-2016, 08:53 PM
Actually 112 mph speed rating.
PRIDEnJOY
Old 07-17-2016, 08:59 PM
One of my to-do list of things on my car...
Since I have a very early Serial# and questionable age and source of components when built.
Even if was a new suspension during the build the bushings are all soft rubber for a family sedan.
Personally I won't go so far as needle bearings or Beryllium Copper bushings since I'm not a racer.
BMW E36 Performance Suspension Components
Active Autowerke E36 BMW Differential Support Bracket (DSB) - $265.00 | Active Autowerke
So whats happening when the hop occurs take a look at this 2015 Mustang video. The principles are the same.
The fore-aft motion of the wheel causes the breakaway. But the other areas (Diff) are all over the place as well.
[ame]https://www.youtube.com/watch?v=91kQSQ8NHME[/ame]
IRS cars typically suck at the strip.
Old 07-18-2016, 06:27 AM
tamanaco's Avatar
spdbrake...thanks for the links. I have found that the CC forum folks to be helpful.
Yep, I know IRS car suck for launches in 1/4 mile stuff.
I see the BackDraft Boys have solid mount for the subframe and the third member.... http://www.backdraftparts.com/produc...-bushings.html
Turner Motor sports has solid on the diff ears, delrin on the nose... https://www.turnermotorsport.com/p-3...36-m3/?pdk=AgE I like that configuration.
Old 07-18-2016, 08:14 AM
lovehamr's Avatar
Stolen Avitar
I see the BackDraft Boys have solid mount for the subframe and the third member.... Backdraft Parts - Solid Sub frame bushings - Rear Suspension - Suspension - Products
I used them in both of my big block cars, used sticky road race rubber and never had a problem. The car would just squat and launch. So yes, if you still have all the rubber in your rear suspension, I would get rid of it when I fixed whatever broke. I used these as well: http://www.backdraftparts.com/produc...mountings.html
Old 07-18-2016, 08:30 AM
tamanaco's Avatar
Lovehamr...what do you use on the trailing arms...solid, delrin or urethane?
Old 07-18-2016, 08:37 AM
lovehamr's Avatar
Stolen Avitar
The spherical bearing. Backdraft Parts - Trailing Arm sperical bushings - Rear Suspension - Suspension - Products
Old 07-18-2016, 02:09 PM
Grey 65's Avatar
The rear of my Pro Class Autocross car has the following installed along with JRi custom valved double adjustable shocks.
Rear Adjustable Camber Arms
Rear Outer Upper AND Lower Trailing Arm Ball Joint
Rear Trailing Arm Bushings (RTAB) - Turner Monoball Race
Rear Subframe Bushings/Mount Set - Turner Solid Race
Rear Control Arm Upper Inner Bushing - Turner Race Monoball
Differential Mount Bushing Set, Poly 75D 14mm Front Bolt
Kevin...
Old 07-18-2016, 03:04 PM
Those bmw parts have to be pricey as hell.
PRIDEnJOY
Old 07-18-2016, 06:02 PM
Cashburn's Avatar
Backdraft Racing Dealer
Not really. And since there are a ton of companies making aftermarket parts for the suspension design there are many options and some price competition. A lot better than a custom suspension with only a supply chain though the manufacturer of the car.
IT'S NOT REAL. IT'S UNREAL.
VINTAGE MOTORSPORTS
Old 07-18-2016, 06:33 PM
I guess if you don't buy oem BMW parts you can save a little.
PRIDEnJOY
Old 07-19-2016, 05:47 AM
tamanaco's Avatar
Kevin...
Nice list of parts! Thanks!
Do have a questions. all are solid mounts, except the diff mounting is Poly...the reason you selected this poly mounts for the diff is?
Thanks, Bill...
Old 07-19-2016, 10:40 AM
Grey 65's Avatar
Thanks, Bill...
The entire suspension is without rubber or poly as I want to eliminate as much deflection as possible. This makes the handling much more predictable and allows me to pull higher G's... We pull around 1.3 G's when turning and around 1 G accelerating and braking. And we change directions a lot. An autocross is basically a road course without the straits....
The poly diff mounts are there as I want a weee little bit of deflection there so as to slow down the shock load transfer to the ground under load and back to the diff when you release the load.
Kevin....
Old 07-19-2016, 03:41 PM
Cobra Make, Engine: ERA 427 S/C, Ford 427 Side-oiler 2x4 bbl
Which Cooper tires do you have?
I have the Cooper Cobra tires on mine and I could swear I looked it up and came up with mid-90 (95? 98??) mph ratings.
But I could be wrong and besides, I'm not *too* worried about taking a 95mph rated tire to 110-115mph for a short time. Sustained might worry me.
Phill
Old 07-19-2016, 09:31 PM
cycleguy55's Avatar
Phill
Cooper Cobra tires are T speed rated (118 mph / 190 km/h), except for P295/50R15 which is S speed rated (112 mph / 180 km/h).
Cooper COBRA RADIAL G-T Tire Reviews (2 Reviews)
Tires Speed Rating | 1010Tires.com Discount Online Tire Store
Brian
Old 07-19-2016, 09:34 PM
Those tires will probably last 60,000 miles.
PRIDEnJOY
Old 07-20-2016, 12:47 PM
tamanaco's Avatar
Mine are Cooper Cobra Radial G/T 295 50 15's
