Like Tree1Likes
  • 1 Post By Late Apex
Old 09-30-2016, 06:53 PM
Cobra Make, Engine: Backdraft - Iconic 427
Default touch up paint
Does anyone know where to locate ppg globel toner white for the white strip on a backdraft cobra?
No luck finding a paint code for it. Trying to get a touch up pen or brush bottle.
Old 10-01-2016, 03:36 PM
mln385's Avatar
Cobra Make, Engine: BDR
Do you know the paint code? If you do try Automotive Touch Up Paint from PaintScratch - Order Pro Grade Paint - PaintScratch.com
Old 10-01-2016, 05:53 PM
That is my issue , not sure of paint code.
Old 10-01-2016, 06:06 PM
csw csw is offline
Cobra Make, Engine: Backdraft #949, 392 FMS
Although I bought mine used, it came with the build sheet which had the color listed. Mine is PPG Royal blue. I went to the local PPG distributor and they also color matched the white stripe so I'd have a touch up can for both colors. Carquest/advanced also sells paint and should be able to match (I think they do DuPont paint).
Old 10-02-2016, 05:35 AM
Dwight's Avatar
Smile
pheagles don't know where you live but around here we can drive our cars to the paint supply shops and they will use a machine to code read the paint. This will give you true color which includes sun fade, etc.
I took the trunk off a Cobra a couple of years ago and took it to the paint store for a reading on the blue and white. We needed a match so we could paint the new hard top. Perfect match.
Dwight
Old 10-02-2016, 04:27 PM
Karl Bebout's Avatar
PHeagles, as Dwight said, find an automotive paint supplier. There's a pretty good probability they'll have some sort of machine that can recognize and identify about any paint color. If you get a color code, "Scratch Doctor" makes very good touch up paint that's good for small chips.
Karlos
Old 10-02-2016, 04:47 PM
Thanks for the advice. If I can't get the code from the dealer who sold it I will try to find a paint supplier. I live in the Manheim PA so there has to be a paint supplier here in the Manheim auction area.
Old 10-05-2016, 05:21 PM
Call Reg at Backdraft, give him the car#.They should have the paint code in there files.
Old 10-06-2016, 07:07 AM
Cobra Make, Engine: BDR, Stroked small block
my car is #251. Mine is White DuPont 4483 (RM-A1630)
Old 10-13-2016, 11:02 AM
Cobra Make, Engine: 1963 Corvette Grand Sport Coupe. ZZ502FI. 502 HP
I just got a small chip on my white stripe BDR of course right where the clear bra ends. I spoke with my BDR dealer about the paint code and was told every time BDR uses a white paint its a little different shade each time and they really can't help. Bottom line is I bought the Duplicolor Chrysler Bright White touch up (Amazon) and it matches perfect! Hope this helps.
Quentin Z likes this.
Your ride should not be to get from point to point. It should BE the point!
Old 10-13-2016, 03:27 PM
Cobra Make, Engine: BDR #359, 427R
Default White Stripes
I have BDR #359 and they told me it is PPG Toner White and there is no code.
Toner White!
Old 10-13-2016, 03:54 PM
csw csw is offline
The PPG dealer scanned my white stripe and it came back PPG base white if that helps.
Old 10-29-2016, 07:10 PM
Thanks for the feedback. Waiting on my BDR dlr to get a paint code from Factory.
Old 11-04-2016, 07:10 PM
Told the correct color for white strip is mercedes artic white, code 147. Hope this helps others looking for a match.
