February 2026
Like Tree6Likes
  • 3 Post By scottj
  • 2 Post By bobcowan
  • 1 Post By bobcowan
Old 10-13-2018, 06:16 PM
bobcowan's Avatar
Default Brake Booster Replacement
This job is a royal PITA. I'v been working on it most of the day, and now I'm stuck.
My brand new car has terrible brakes. The new brake booster is dead. I spoke with Perry Jackson at Iconic Parts (BDR), and he told me what booster to buy. It's a Porsche 944 part.
I got the new part yesterday, and it almost fits. The problem is that the pedal rod is about 2" too long. The old booster has a fully threaded rod, and it's been cut down.
But the new part doesn't have a fully threaded rod, so I can't really cut it down far enough to make it work.
I removed the old rod from the old booster, but I had to destroy the booster to do it.
I have some ideas, but I don't want to start cutting without asking for advice.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
Old 10-13-2018, 07:22 PM
Cobra Make, Engine: Everett-Morrison, 434 cid
Do you have an ATE or a Girling booster? Here's the procedure: https://www.rjnunnally.com/how-to-fi...ter-to-an-e30/
Morris, spdbrake and BDR_Boy like this.
Old 10-13-2018, 08:37 PM
bobcowan's Avatar
Wow. That is perfect! I had a plan in my head that was a lot more complicated and time consuming. Thanx so much for saving me all that work. I will do this tomorrow.
scottj and cycleguy55 like this.
.boB "Iron Man"
Old 10-15-2018, 08:25 PM
bobcowan's Avatar
Done, done, and done. Thanx, Scott. Couldn't have done it without you. Well, I probably could have. But it would have taken me a week. The brakes are now working as intended. Maybe not as good as I would like. But as intended.
This job was a royal PITA. Threading and trimming the pedal rod was the easy part. Had to remove the side vent, steering shaft, and valve cover.
scottj likes this.
.boB "Iron Man"
Old 10-16-2018, 07:41 AM
Glad it worked out Bob. I have to do the same thing on my brake and clutch masters for my pedal assembly. Of course. the Tilton rods are easily removed.
