January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Old 08-30-2019, 10:26 AM
Default Rear driver's wheel - some play?
Hello - BDR #885 (3000miles) and I noticed when I went to increase the ride height that the rear driver's wheel has a small play.
Here a video showing the issue. Any ideas? Is it dangerous - normal - what is the solution?
Link: https://drive.google.com/open?id=144...uRcBZXim4WYlHj
p.s
the other side has no play
Old 08-30-2019, 11:36 AM
Is the axle bolt under the center cap tight?
and also the lug pin bolts.
Old 08-30-2019, 06:56 PM
Cashburn's Avatar
Backdraft Racing Dealer
Probably needs the bearing replaced.
IT'S NOT REAL. IT'S UNREAL.
VINTAGE MOTORSPORTS
Old 08-31-2019, 01:46 AM
Thank you spdbrake & Cashburn- I will check.
Can you point a link with the bearing needed? I am overseas (Greece) and need to place online order
Old 08-31-2019, 04:49 AM
Grey 65's Avatar
Cobra Make, Engine: BDR #888, Keith Craft 408
Here you go.... Timkin 51306
Kevin......
It isn't how fast your car can go
It is how fast your car can change direction
Home of Fake Snake Racing
