November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Like Tree3Likes
  • 2 Post By bobcowan
  • 1 Post By Gaz64
Old 07-26-2020, 08:31 PM
SBSerpent's Avatar
Cobra Make, Engine: BDR build #983, FRM 392
Default Spare tire options
I don't have one at the moment but I am considering one for those long hauls in the Cobra. What are my options?
Old 07-26-2020, 10:30 PM
Gaz64's Avatar
Depends on your tire sizes front and rear, but a space saver of the same rolling diameter as the rear could still be fitted to the front, and get you to the next tire shop for repairs.
A 4 inch rim that matches your wheels and a tire like eg: 155/80/17?
Gary
Old 07-27-2020, 07:57 AM
IMLost's Avatar
Cobra Make, Engine: BDR #178 United Speed World Special
I take a list of dealers and locations for overnight shipment. I also carry plugs, glue and a air pump.
Doing and driving what other people dream about!
Old 07-27-2020, 08:43 AM
bobcowan's Avatar
Fortunately, flat tires are not common. Kinda rare, actually. I carry a plug kit, compressor, and AAA card.
A space saver spare can be somewhat difficult. Getting the right diameter and shouldn't be too hard. But you also have to find a wheel big enough to fit over your rotors and calipers.
It takes up a lot of limited trunk space, too. First you have to find a spot for the space saver. Then, you have to find space for the flat tire.
Gaz64 and Jaydee like this.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
Old 07-27-2020, 10:23 AM
Grubby's Avatar
Cobra Make, Engine: ERA 838
Many long road trips in Cobras and no flats. I carried a plug kit and two cans of fix a flat.
If I shredded a tire I had my phone.
John
Old 07-27-2020, 12:04 PM
SBSerpent's Avatar
A plug kit is a good idea. I do carry a can of fix-a-flat as well.
Yeah, I kinda figured that trying to carry around a spare is alot more difficult on these cars. I guess the next best option is preparedness - plug kit, fix-a-flat, 12V air pump and my AAA card,
Old 07-27-2020, 01:59 PM
Cobra Make, Engine: ERA 427sc
I have a plug kit, but this reminded me I never found a good canister based air refill kit. Those foam based fix-a-flats make a horrible mess at best and can cause some real damage in unlucky situations.
Did a little research just now, and think I'll pick up one of these:
https://powertank.com/products/ptm-0125
Old 07-27-2020, 03:18 PM
SBSerpent's Avatar
You can save yourself quite a bit of money if you just buy a plug kit and a 12V air pump. But of course, you'd have to have a 12V receptacle wired to the battery which is what the previous owner did on my car. I guess he wanted the convenience of charging his phone when needed.
But I paid under $30 for my pump and $15 for the plug kit. Some additonal money and time to wire the 12V source and you've saved yourself quite a bit of money
Old 07-27-2020, 04:53 PM
Dwight's Avatar
Smile
three cans of flat fix and 42,000 miles later. I still had not used them.
Old 07-27-2020, 06:15 PM
Cordless Milwaukee M12 compressor. $100. We use it for a lot of things.
Dan
427 CSX 3000/4000 and Shelbys.
All gone ! Was a Hell of a run
Now ... The dogs car
Mercedes E63S station wagon. 603hp
Old 07-27-2020, 08:52 PM
FredG's Avatar
Cobra Make, Engine: Backdraft Car #1209 Roush 427R
Default Options from old thread.
Oh no!!!I have a flat.
Old 07-27-2020, 09:21 PM
Harbor freight Air compressor and tire patch kit. $15.
Jim
Old 07-27-2020, 10:12 PM
SBSerpent's Avatar
Oh, and almost forgot. I also carry a low profile scissor jack that I kept from my Acura Integra before I junked the car. Just in case.
Old 07-28-2020, 05:10 AM
Cobra Make, Engine: Shelby, 1964 CSX2367, fully restored, I'm the second owner, SAAC Div 1 Premiere 2003&2012
Default Combined compressor and slime
New Mercedes and Porsche cars come with a small briefcase device that has the compressor and repair glue that injects thru the same hose. Slime is one brand that is readily available. Less Han $50. I used one once and it was ok.
Dave Wathen
1964 CSX2367
1938 Jaguar SS100
1953 XK120 roadster
1966 Etype roadster
1971 280SE 3.5 Cabriolet
Old 07-28-2020, 05:30 PM
Gaz64's Avatar
I have used a similar product in the belief it could stay in there, until another puncture in the same tyre required removal. I nearly couldn't use the wheel because of the corrosion it caused.
Note the highlighted:
Myth No. 5:
Tire sealant is not safe for my wheel rims
Busted! Slime tire sealant is specially formulated with rust and corrosion inhibitors that work to protect the integrity of your finished metal rims. In automobiles, we recommend removing the tire sealant and repairing your flat tire within 3 days or 100 miles. In non-highway vehicles (such as bicycles, ATVs, trailers, farm equipment, etc.), Slime’s tire sealant will prevent flats for up to 2 years without causing damage to your rims.
Slime tire sealants are designed to be easy to use, safe for consumers and the environment and designed to keep your wheels moving. No more flats with Slime!
IMLost likes this.
Gary
Old 07-29-2020, 10:15 AM
Default Flats
Flats are common or for me they are but not when driving. Three of them in two years because of nails in tire causing slow leaks.
There are no spare tire options if you have pin drive wheels.
I do like others- carry plug tire kit and small cheap air compressor along with a bottle jack.
Fix a Flat can or Slime is a nice option to car, too.
Old 08-01-2020, 01:13 PM
Quentin Z's Avatar
Cobra Make, Engine: Backdraft #272, 351W
Originally Posted by SBSerpent View Post
...But of course, you'd have to have a 12V receptacle wired to the battery which is what the previous owner did on my car.
Or you could buy this from Amazon like I did!:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old 08-01-2020, 01:45 PM
Default You want to see a pissed off tire guy
Bring him a tire/wheel full of fix a flat. Iver heard that they will dismount then hand the gooey mess back to you for cleaning...of course with so many kraut cars coming with the silly repair kit some probably will clean the mess up.
Picture a quart of spilled rubber contact cement...
My $.02
(I have a spare)
Superformance 1764
Built 427W
Aiken SC USA
Old 08-02-2020, 06:24 AM
Grubby's Avatar
A large number of new cars come with the tire inflation kit instead of a spare.
My 2012 Mustang has one.
I just picked one up on Ebay for the next Cobra. You can get them from virtually all makes. The GM variant was the cheapest for the style I like. It is a nice compact unit with air compressor and sealant in one package.
The inflation kit and a package of tire plugs should be all that is needed for some long road trips.
John
Old 08-03-2020, 06:33 PM
xb-60's Avatar
Just been through this myself. Bought a new car, and it had no spare....just the little compressor and the "goo". We do a reasonable amount of country driving (I'm in Australia, big distances between major cities) and I figured that "goo" won't be much use if I have a blowout or a damaged tyre, so went the expensive way and bought a new full-size wheel and tyre for a spare.
Couldn't buy one from the dealer, but luckily could easily get one from a local tyre/wheel retailer. Not cheap, but I now have peace of mind.
Are skinny pin-drive wheels available for our cars?
Cheers, and good luck with the "goo"
Glen
