Old 02-07-2021, 10:24 PM
SBSerpent's Avatar
Cobra Make, Engine: BDR build #983, FRM 392
Default Spark plug
What is the recommended spark plug for a stroked 351W Ford Racing Motor (392 CID)? This is the 'stock' motor that came with my 2011 BDR #983 build.
Old 02-08-2021, 01:11 AM
eschaider's Avatar
What does the engine builder say to run?
Ed
Old 02-08-2021, 04:58 AM
Tommy's Avatar
No guarantee these are right for your engine, but the 408 Windsor I used to have used Autolite AR 3932. They were a little on the cool side and tended to foul when not run hard.
Tommy
Previously owned EM Cobra
Old 02-08-2021, 08:31 AM
bobcowan's Avatar
I always used a standard Autolite 3924 copper core plug. They're easy to find, inexpensive, and work well in all conditions.
You have to change them about every 25-30K miles. But for most Cobra's that's every 5-6 years or so.
You can spend a lot more money on iridium and platinum. All that does is extend service life. And some ignition systems don't do well with those types of plugs.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
Old 02-09-2021, 06:12 AM
I agree on the Autolite 3924 like Bob. Also the Autolite AR3924 (cutback strap) are great. I've had a my best readings with NGK BKR6E (6962) v-power plugs.
But I admit that's after I had tuned the carb using an AFR gauge.
Old 02-09-2021, 07:13 AM
Moritz55's Avatar
Cobra Make, Engine: Superformance, '65 427/MKIII with Roush V8 - 351W w/770cfm 4BBL Holley, 514hp
I have a Roush 351W stroked/bored to a 427cu and MSD 6AL , 510HP.
Roush recommends for my engine Autolite AR3923, heat range 3 (one heat range cooler that 3924) .. however I have better luck using NGK's so I use the equivalent NGK BKR6E-11, heat range 6 (stock #2756) just as "spbrake" recommends.
I also gap my plugs to ~0.045" because of the MSD 6AL.
Many thanks,
Mark
Superformance: SPO2454 , Titanium w/Black Stripes
Engine: Roush 427SR w/770cfm 4-Barrel Holley
Transmission: Tremec TKO-600
