Like Tree2Likes
  • 1 Post By spdbrake
  • 1 Post By twobjshelbys
Old 02-11-2022, 09:39 PM
Default Tko 600 clutch slave cylinder
Does anyone know what the exact part number is for he clutch slave cylinder in these pictures. Tia
Old 02-12-2022, 04:52 AM
Mazda B2200 pickup Dorman PN CS103489
Where I bought mine:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old 02-12-2022, 05:35 AM
Cobra Make, Engine: AC cox 2699 roadster Riverside FIA RSR2001
I use a Nissan 620 slave. Important to match bore size .
Duralast Clutch Slave Cylinder 11797
Old 02-12-2022, 05:37 AM
Old 02-12-2022, 05:43 AM
The mounting holes will not line up they are horizontal. I originally bought the Dorman cs103489 but the mounting holes are going the wrong way
Old 02-12-2022, 05:58 AM
Tommy's Avatar
I don't know the answer. But I have two local auto parts stores where the same people have been behind the counters for decades, and they can often match up parts by sight. The chain parts stores are usually useless.
Tommy
Previously owned EM Cobra
Old 02-12-2022, 06:44 AM
My mistake.
That is an odd mounting, but I've seen it somewhere before. Can't remember where though.
You could go with the the PN I linked and use a BDR adapter.
https://www.iconicparts.com/clutch-s...g-bracket.html
https://www.iconicparts.com/clutch-slave-assembly.html
Jay (Cashburn) at Vintagemotorsports has their own setup and maybe of more help.
BDR_Devin likes this.
Old 02-12-2022, 05:33 PM
Do you think it would be worth it to switch to a hydraulic throw out bearing?
Old 02-12-2022, 06:36 PM
I had considered it an item on my to-do list for awhile. But then reading all the issues folks were having with leaks and no one company stood out as being more reliable I've since changed my mind. All that coupled with the dropping of the trans and bellhousing, then re-aligning the bellhousing and reinstalling the trans, it then fell off the list. Still I won't say never though, at least until I puke a clutch or tranny.
My current project is in that area.
Girling Push slave cyl.
A different Willwood master,
Tilton remote 3 tank resv
Remote lines from the brakes and clutch to the Tilton resv.
Old 02-12-2022, 06:56 PM
twobjshelbys's Avatar
They are extremely sensitive to alignment. And to most I think they would consider that the alignment was in the tolerances of most systems, so it's to say that the HTOB system is subject to "less than perfect alignment". And if you have troubles, a labor intensive fix. More people have gone the other direction - abandoning HTOB for the classic clutch master/slave.
Tony
CSX4005LA
Old 03-01-2022, 06:31 PM
I figured out which cylinder it was. Dorman CS12247 Fits perfects and works great!!!!
