Like Tree7Likes
Old 04-27-2022, 08:41 AM
I may have to order one, 1 key would be nice
Old 04-27-2022, 12:02 PM
cycleguy55's Avatar
Originally Posted by FlyingGumby View Post
Didn’t like the fit of a recently installed Lucas ignition switch made for a 3/4” hole. Searched for a new switch by shape and size of the original key thinking it could be cut to fit an existing locking gas cap.
Found this one for $10…
Fits dash perfectly and the key worked with locking gas cap unmodified.
If that key worked in your gas cap unmodified, does that not imply the key is somewhat generic, therefore indicating anyone with a similar generic key could use it in your ignition? I hope you have another form of security, should you ever need to leave it unattended.
Brian
Old 04-29-2022, 08:24 PM
FlyingGumby's Avatar
Cobra Make, Engine: BDR #870 Salsa Red w/White stripes Roushcharged 4.6L 3V
My original key opens the gas cap but does not turn the new ignition switch. I suspect a cap will open with any key that fits the slot but only a specifically cut key will turn the switch. A bigger issue is the exposed wires behind the switch that could not be easier to hot wire. Other safety measures are needed.
cycleguy55 likes this.
Old 04-30-2022, 03:55 PM
twobjshelbys's Avatar
Anti theft and cobra are mutually exclusive. There probably isn't an easier car to hotwire. Remember it's a race car
CSX4005LA
Old 05-01-2022, 06:39 PM
Problem solved.
Yes it’s a joke but I do use it on my El Camino!
Old 05-06-2022, 04:25 PM
BDR0572's Avatar
Cobra Make, Engine: BDR, Roush 402R
Default Millennial anti thief device is installed
It is called a stick shift
twobjshelbys likes this.
Old 05-06-2022, 04:29 PM
BDR0572's Avatar
I'm never to far away from her ,but if I am I always flip the electrical cutoff key and carry it with me . they will have to push or tow it away .
