Old 01-28-2004, 10:34 AM
Cobra Make, Engine: Former owner of BDR 127......
Default Boudy or Reg...BDR and seat heaters
Can you guys verify whether the seat heaters advertised on the front of the forum (www.cobraheat.com) will work with the BDR seats?
It seems as though as long as the seat are a two piece unit, then it should work.
Also, with the addition of a heater, seat heaters and stereo (I know) will I need a larger alternator or anything else to avoid a big drain on the car? Any insight you have as compared to other cars you guys have shipped would be appreciated.
Thanks,
- Snak Iyz
Old 01-28-2004, 04:21 PM
Cobra Make, Engine: Backdraft #101, 342 stroker
I asked the same question about the seat heaters. They use 70 watts. That translates to about 6 amps if I did my math right. Between charging your battery, heating the seats, and running heater fan you should be ok. Now that stereo if it is 2000 watts you may have concern
tfarhood
