Old 02-01-2004, 08:46 AM
Cobra Make, Engine: SPF 2682, Roush 427
Default Emergency Brake
My emergency brake support bracket just broke at the smallest point between the two mounting bolts. Probably because of the strain of pulling it at an angle from the drivers seat. Has anyone had to weld one of these? The handle never would go to the floor unless you moved it to the right to clear the tunnel.
Chet
Old 02-02-2004, 08:04 AM
Problem solved. I had the bracket welded and reinforced.
