Old 04-25-2005, 06:31 AM
Default Slave cylinder mouting plate
Does anyone know where I can get a new slave cylinder mounting plate. The original installer did not mount it correctly and the slave cylinder rod activates the clutch arm at a sever angle. I need a new plate to drill some new holes and mount it correctly. I have the Tremac 3550. Thanks in advance
Old 04-25-2005, 08:07 AM
Cobra Make, Engine: SPF 2682, Roush 427
If you have a Backdraft, call them. They will get you one.
Chet
Old 04-25-2005, 06:57 PM
Cobra Make, Engine: Backdraft #101, 342 stroker
Call Reg at Backdraft. They use a two piece bracket that is fairly adjustable. Two bolts into the bellhousing, and two more for the brackets. It works well for the push style slave. If your car has the pull style that some of the Backdraft dealers are using, it is a different set-up.
tfarhood
