Old 08-15-2005, 07:50 AM
FQV FQV is offline
Cobra Make, Engine: BackDraft,X302,T5
Default Car # 227 From Olgivie Automotive
Just picked up my Grey with silver stripe BDR. Car was assembled by Olgilvie automotive. Bill and Rich assembled the car and went over the top to ensure I was happy with the build. The car from BDR has some inherent problems (IE not enough adjustment in the suspention for toe in, toe out on the rear). Bill and Rich had the adjustment pieces machined and got the front and the rear to within " BMW spec" . Because of this the car drives awesome, noshake at any speed. All in all the BDR was a good experience with Olgilve motors overcoming any shortfalls of the car as it was delivered. The BDR is a great car but it is only as good as those that assemble it.
FQV
Old 08-15-2005, 10:50 AM
Cobra Make, Engine: SPO 1850, 392 stroker
Yea well my experience with them is the worst ever. I hope you dont ever have a problem because once you do, Jeff will never return your calls!!!!
Old 08-15-2005, 11:53 AM
JayBar's Avatar
Cobra Make, Engine: BDR#078,408 Dart Block, TKO 600,Indigo Blue, White Stripe
Send a message via Yahoo to JayBar
Default Re: Car # 227 From Olgivie Automotive
It is assembled in South Africa, it is only "tweked" here.
JayB
Jupiter, FL
Old 08-15-2005, 01:25 PM
FQV FQV is offline
Default Re: Re: Car # 227 From Olgivie Automotive
Assembly (or maybe I should have qualified, final assembly) which includes engine/ trans install, is a little bit more than tweaking. Tweaking is fixing all the issues mentioned in other threads in this forum.
So let me restate this"The BDR is a great car but it is only as good as those that perform the final assembly and tweak it"
FQV
Old 08-15-2005, 01:56 PM
BUCKEYE COBRA's Avatar
Cobra Make, Engine: Backdraft #20 302 T5
Mine is "tweaked" and running great!
Lots of fun
(ready for more HP)
John
