| 29 |
06-04-2005, 03:39 PM
fl
Cobra Make, Engine: backdraft racing 302 ford
Tire preasure
Hi
What tire preasure for 15" Tires. My freind has a super performance and he says to run 21 to 26 psi whats backdraft say?
Thanks ED
Ed
06-04-2005, 08:40 PM
Beam Me Up Scottie
MA
I also have a Superformance Cobra, but I have 18 PSI in the tires for normal driving and they work very well at that pressure. For road racing, use 25 PSI. All pressures cold, not hot. This info from the owners manual. You did get one????
Warren
06-04-2005, 08:42 PM
Beam Me Up Scottie
MA
Forgot to mention that the tire are Goodyear
Front Wheels & Tires: 8” wide rim 255/60 R15
Rear Wheels & Tires: 10” wide rim 275/60R15
Warren
06-05-2005, 02:18 PM
Cobra Make, Engine: Backdraft Racing BDR144
BDR Tire Pressure Recomedations
Ed,
Armond at CA Cobra recommended the following tire pressures for the BFG Radial T/A 15" tires.
Front BFG P235/60R15 = 28 PSI
Rear BFG P295/50R15 = 25 PSI
I have used these recommendations and they seem to work very well for me.
Wayne W.
Pewter with Steel Gray Stripes
06-22-2005, 10:11 AM
IL
Cobra Make, Engine: 396 long block, PROBE Forged Dished pistons 8.75 to 1 and Vic Jr. heads from Engine Factory. Tremec TKO. BDR#244 Sterling Gray/Silver stripes. 17in polished wheels, glove box and tonneau cover.
For the 17in wheel combo:
29 on the back
28 front
Sid
T.S.B. of The West Side Cobra Club
N.D.N.P.N.P.
06-22-2005, 11:25 AM
WI
With the BFG 15" wheels I use 32psi all around. Tried different combo's from 26psi on up. The grip (if you can call it that with the BFGs) is not noticably different, but the response is much better than the low pressures.
Brent Dolphin
06-23-2005, 02:06 PM
Cobra Make, Engine: Backdraft #90, 351w,Tremec 3550, SB100 SOLD
thunder1
Well, I can see all the answers probably just cleared up the old tire pressure question with no doubt! Ha! It looks to me like a Backdraft with its BMW based suspension will have its own set of tire pressure settings. So, I can only agree with Secret Squirrel and go with 28 front and 25 rear. Of course, I got the same numbers from his source, Armond at California Cobra. My car runs and sticks great at this pressure. But play around with it some, you may have better luck with other settings.
06-23-2005, 03:00 PM
Considering the light weight of the car and the larger than normal size of the tires I would think that anything over low 20s is reducing the contact patch a lot.
06-23-2005, 04:39 PM
WI
I probably don't have the optimal contact patch, but the stripes on the pavement cover the whole tread width and radial tires aren't as sensitive to pressure as the bias ply. The difference between 26# and 32# is dramatic. But then I don't have a Backdraft and they may react to tire pressures differently.
Brent Dolphin
